Porting a Radix?
Old Aug 26, 2005 | 03:48 PM
  #61
I was thinking of having my Radix supercharger ported and did some research and found that the Radix is allready ported.I talked to the people who port the Lightning superchargers and they said that there was nothing more to port.They did offer to port the intake tube for about $400 and I declined their offer.I did have an adaptor plate made locally to fit a 90mm throttlebody and then bored the intake tube to match the 90mm openning.That seemed to help things flow a little better.
Old Aug 26, 2005 | 04:04 PM
  #62
Mr. Sandog's Avatar
Originally Posted by FuelSlut
Can someone clarify this? Does lower compression on a blown motor equal more power? Should these H.O. 5.3 and 6.0 guys get pistons to lower compression?. No one has really clarified this point. seems to me that lower compression might lower resistance to the foced air coming in on compression stroke? I'm just not sure.
AFAIK, the only reason to run lower compression is so you can run more boost, and run it on pump gas without detonation. A lower compression motor by itself (5.3L @ 8.5:1 compression) puts out less power than an equivalent size motor with higher compression (5.3L @ 10.5:1 compression), but can handle a lot more boost. If you aren't going to run boost then there is really no reason to lower your compression, or go with a low compression motor.
Old Aug 26, 2005 | 09:33 PM
  #63
BlownChevy's Avatar
blownerator
25 Year Member
Timing makes better power than boost
Old Aug 27, 2005 | 01:03 PM
  #64
hey big B, howd that pump voltage booster i heard you were testing help out? (off subject i know) but ive heard pretty good results from that add-on......
dsbodley
Nov 14, 2015 09:46 PM
gmcyukon
Oct 3, 2015 11:03 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
old motorhead
Sep 29, 2015 08:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
