Pistons...
Old Sep 28, 2009 | 05:53 PM
MikeGyver's Avatar
Originally Posted by f4tal
but do dished have advantages over flat top?? or just mainly for comp ratios??
Choice B.
Old Sep 28, 2009 | 11:58 PM
f4tal's Avatar
Originally Posted by MikeGyver
Choice B.
thanks!
david i already have some 862's that im getting port an polished yada yada.
lol im going to try those out... but PM on those 317's JIC
Old Sep 29, 2009 | 10:33 AM
Rick_Vor's Avatar
You could run Wiseco -11cc dished pistons with your 862 heads. That would put you around 10:1 and then swapping to 317's down the road would drop you down to around 9:1.
Rick
Old Oct 2, 2009 | 09:06 AM
FastKat's Avatar
Find out what piston material is best for your application... there are two alloys... I think one is 2618 and the other is 4xxx. One is stronger and is said to scuff your cylinder walls in as little as 5k miles without a coating on the skirts, and the other is softer and not as strong but said to make your bores last longer and to be quieter on startup. There are very reputable people on each side of the "which is better" argument.
Old Oct 2, 2009 | 10:40 AM
$nake Charmer's Avatar
just like corey said... it all depends on your heads chamber and you pistons dish... im running a -10 cc dish piston, and a 70cc chamber on my heads and have a 9 : 1 CR... my setup is good for alot of boost, but suffers greatly under NA...
Old Oct 2, 2009 | 10:44 AM
FastKat's Avatar
I think the LS9 in the new ZR-1 Corvette runs a 9.1:1 CR.
Old Oct 2, 2009 | 11:20 AM
thats weird... i think maybe they know that most will eventually boost it... because they could ave got so much more out of it with a higher CR
Old Oct 2, 2009 | 12:29 PM
sharpshooter's Avatar
isn't the LS9 factory supercharged?
Old Oct 2, 2009 | 01:12 PM
Coban's Avatar
Yea, Maybe he's thinking about the LS7. 11:1 compression
Old Oct 2, 2009 | 01:47 PM
FastKat's Avatar
Yea the LS9 is supercharged. The original poster wants to build an engine that is boost friendly for a turbo setup he plans on adding later on. Both the supercharger and the turbo are going to like a lower CR better.
The point I am trying to make is that the LS9 Corvette probably runs "normal" when you're not beating on it... with a 9.1:1 compression ratio. When you're just doing normal stop an go driving, the supercharger isn't really doing a whole lot... not until you put your foot into it
rcmf5525
Sep 27, 2013 08:58 AM
diRty?biRd
Jun 13, 2013 07:05 PM
Corverado SS
Jul 8, 2012 06:35 AM
silveradokidd_4518
Jan 8, 2011 04:25 PM
silveradokidd_4518
Dec 17, 2010 03:38 PM
