PCV setup on a forced induction engine
Old Feb 6, 2012 | 09:08 PM
TXjeepTJ's Avatar
Default PCV setup on a forced induction engine
I feel this topic is not talked about much (no thread dedicated to it after doing a search) and it is actually really important/could ruin your engine if done wrong
So, what setups are good?
I have stock intake (also no aftermarket valley cover). Right now I have passenger side vented to atmosphere w/ a filter at the end. Drivers side is connected to vacuum, but I replaced the stock PCV valve with a "one way" check valve style PCV. I feel this check valve isn't doing it's job the best it can though. Because of this:
I think I am getting blow by still, as it idles poorly after you hold the engine at a rev and sometimes wants to die. Oil is also breaking past the turbo seal and flowing into my cold pipes under boost (which is contaminating my MAF and making the truck run horrible). What are my other options for a PCV setup?
Old Feb 6, 2012 | 09:58 PM
Atomic's Avatar
I have a gauge for that
This is actually talked about quite a bit. I have my passenger side vented with a filter, and the driver side going to an overflow can with a filter on it.
Old Feb 6, 2012 | 10:59 PM
charcold-bowtie's Avatar
I plan on basically running both of mine thru a homemade catch can, then pre turbo
Old Feb 6, 2012 | 11:12 PM
TXjeepTJ's Avatar
On both of those setups, should you worry about any vacuum pulling the fumes while not in boost? or is that more of an "environmentally friendly" issue, than a screwing up your engine issue?
Old Feb 6, 2012 | 11:30 PM
nonnieselman's Avatar
I just ran both valve cover vents to a "T" and put a filter on it. right now its back like factory
I think when i go back turbo ill either vent it again or run the old STS 3 port noid to vent the CC soon as it sees 1psi boost.
Old Feb 7, 2012 | 05:55 AM
joeyc125's Avatar
11 Second Truck Club
I have my passenger side vented with a filter on it, driver side goes to a closed catch can with vacuum from between the turbo inlet and air filter. I've never been a big fan of not having vacuum to pull vapors out of the crankcase, especially running e85 as it seems to have much more condensation. I empty my can every week or so, don't really get any oil goop, but instead I get what looks and smells like 190 proof everclear!
Old Feb 7, 2012 | 06:37 AM
TIM Z's Avatar
11 sec. Truck Mod
Thats a win win situation bud!!! Turbo power and a stihl all in one!
I swear if these LSx engines could crap you would find a golden egg!!
Old Feb 7, 2012 | 09:30 AM
BigKID's Avatar
I am running the same setup as most with a vented pass side valve cover and driver sided thru a catch can to the vacuum source between throttle body and blower inlet. This worked well for me in the lower boost range (<12psi) but now at 15psi I am getting a little more crankcase pressure and it is saturating the pass side filter and dripping on my headers. I am looking into tapping each valve cover with -10 and running both to a vented catch can. I think this will provide plenty of ventilation for wot but I hate to remove the vacuum source for part throttle evacuation. If I could, I would try adding the LS6 valley cover and attaching to a vacuum source. This should provide an ample escape route thru the valve covers during wot and would allow crank case flushing with vacuum on the valley drawing fresh air thru the valve covers during part throttle driving.
Old Feb 7, 2012 | 09:34 AM
TX Tahoe Z71's Avatar
LS6 valley cover and catch can in between valley cover and intake tube. But now that you mention it, I do get a lot of water in my catch can when I run E85. I had never put 2 and 2 together, makes sense though.
Old Feb 7, 2012 | 11:18 AM
black04's Avatar
I have mine like stock on the driver side with a catchcan and check valve in the middle. Passenger side goes from valve cover to catchcan to preturbo.
