PCV and MAF on turbo build?
Old Dec 19, 2016 | 12:00 PM
Bluchevypick's Avatar
I run Mighty Mouse PCV can as well as a ls7 maf on my tbss with a turbo build and no idle issues or oil in the intake.
Old Dec 22, 2016 | 11:39 AM
crashmymax's Avatar
Originally Posted by 0235SS93
FWIW, I run a mighty mouse solutions pcv can on my turbo 2010 with stock maf and have zero issues.
Just wondering how do you have your MMS pcv can setup? How did you run your lines?
Old Dec 24, 2016 | 03:21 PM
0235SS93's Avatar
I have a breather filter for the fresh air inlet on the drivers valve cover, a line from the pcv can to the manifold and a line from the barbedroom fitting on the can to the passenger valve cover. No problems at all. Catches plenty and I have no issues tuning with maf
Old Dec 24, 2016 | 04:45 PM
2ToNe04's Avatar
would be interested to see some pics hows you guys have the catch can routed on your nnbs's.
I had a catch can, but i had a bit of idle flutter, so i removed, but i would love to put it back on there.
Old Dec 24, 2016 | 04:51 PM
TrickTurbo's Avatar
Truck Sponsor
I route
Driver side valve cover to can.
Can to check valve.
Check valve to top of intake.
Passenger side valve cover to breather.
Old Dec 24, 2016 | 04:57 PM
2ToNe04's Avatar
Originally Posted by TrickTurbo
I route
Can to check valve.
Wow thats a nice product! Might have to get one of those and ditch this ebay one i have, maybe after my transmission install.
Thank you for the picture!
Old Dec 25, 2016 | 03:19 AM
Blown06's Avatar
8 Second Truck Club
I can't think of one reason why I'd want a pcv system or any system for that matter (regardless of check valves or anything else) that would circulate air from the crankcase back into my fresh intake stream.
Old Dec 25, 2016 | 10:08 AM
TrickTurbo's Avatar
Truck Sponsor
To pull the crank case vapors out under normal cruising.
Where street trucks spend most of their time.
Moving dirty air from the crankcase through the combustion cycle.
Having a slight vacuum on the crankcase also helps ring sealing.
Other wise you are relying on the blow by from the combustion cycle to push
those vapors out the valve covers all the time.
And this cause oily smell inside the cab.
To each his own but these are just a few reasons.
Old Dec 28, 2016 | 01:14 AM
Blown06's Avatar
8 Second Truck Club
Under normal driving conditions is actually when a set up like that does the most harm. Sucking all those vapors back into the intake stream pollutes the **** out of the incoming charge to the point that it will actually encourage knock and detonation. You talk about how bad the engine bay is polluted without it, so you would rather just suck it back into the engine?
The only other pro you cite is that crank case vacuum promotes better ring seal. Sure it does, if you actually are producing a decent amount of vacuum. I don't believe I have ever seen a pcv set up with the volume capability (small lines and check valves) or efficiency to be able to that.......and if it is.....well see the paragraph above because now you are really sucking up some bad ****.
There are plenty of ways to do what you want, but a pcv system plumbed back into the intake is the worst way to attempt it. If you are that worried about it, a header/exhaust evac will do what you want, and keep everything clean. Otherwise you will need an actual vacuum pump/dry sump oil system which is normally not economical on newer vehicles. Even if you had to run the vent lines to the rear of the car (to prevent the mess/smell you don't want) it would be better than sacrificing your engine.
The pcv system was one of those epa/gov't funded programs that remind me of the dpf situation with diesels, though not quite as bad. In an effort to reduce emissions, the epa said yeah, lets burn more fuel and decrease mileage to prevent a little black smoke. Along with that, the dpf system implemented can be a very costly item to repair....so that along with the fact that mileage got decimated doesn't save anything. All of the sudden, we need a new ULSD fuel that complicates the refining process as well....you get the point.
The pcv system has no business on anything I own.
Old Dec 28, 2016 | 01:19 AM
Blown06's Avatar
8 Second Truck Club
I know you are trying to sell a product here and thats cool. I'm not in anyway trying to **** on that. I'm just voicing my opinion on how things could be better done is all.
