Our new 76/75 Billet.
Old Sep 24, 2016 | 08:15 AM
  #21
Atomic's Avatar
I have a gauge for that
Rick, did you ever finish the cast manifold on the driver side to match your passenger side one? A pair of those with a pair of these would be awesome!
Old Sep 24, 2016 | 03:13 PM
  #22
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by Blown06
What would an ls engine combo look like if I wanted to run these in a twin configuration?
I think it would look really nice.
The layout is done.
Making just a driver side didn't match the passenger side and looked wrong as a set.
So we will need to build these in sets.
It's in the "to do list" just picking battles in which project to finish first.
Over all cost on a twin is so much higher then a single.
And tooling is double what a single is.
If I had enough interest in them would help bump that project forward.
Cast twin manifolds would be in the 1100-1500 price range for both manifolds.
Maybe I need to do a group buy special,
Get people to leave a deposit to show their interested.
Old Sep 24, 2016 | 03:37 PM
  #23
1FastBrick's Avatar
Custm2500's Rude Friend
The layout is done.
I would be down for that!!!
Old Sep 24, 2016 | 06:10 PM
  #24
Turbine side.
Inducer 82.55
Exducer 75.00
Borgwarner are large frame t4. Allowing for larger exhaust wheels.
And take up way more room.
Good deal. And +1 for the BW turbos taking up a fair amount of space.
Old Sep 25, 2016 | 02:48 AM
  #25
Blown06's Avatar
8 Second Truck Club
The layout is done.
I was looking for a little more detail, such as optimal engine size, cam/rpm range expectations, boost levels (race gas or methanol fuel), total horsepower that could be supported, hot side configuration and size, etc. Pretend as if I was asking to put this in a truck like mine.
If you don't know my truck, it's pretty much a drag race only deal (no street significant street time), Rosslers baddest 3 speed trans, 9" rear, 4-link suspension, custom front coil over suspension, 3700lb goal race weight. That sort of thing.......
Old Sep 25, 2016 | 08:44 AM
  #26
TrickTurbo's Avatar
Truck Sponsor
What size engine are we talking about?
Old Sep 25, 2016 | 08:45 AM
  #27
TrickTurbo's Avatar
Truck Sponsor
There's one. .
Old Sep 25, 2016 | 01:56 PM
  #28
JordanH's Avatar
Restricted
I would say 416ci and up would be great for a set of twins like these!
Old Sep 25, 2016 | 02:35 PM
  #29
TrickTurbo's Avatar
Truck Sponsor
These units are rated at 950hp.
Can be used in many engine sizes.
But in a twin I would consider using a small AR.
You are using 1/2 the engine to feed one turbo.
Fuel- race gas or e85. if your really heavy into racing get the fuel from someone who sells race fuels not the pump. At the pump can be a big variable in the quality of the fuel as many have seen just on gasoline.
Inter cooler design will change depending on fuel running.
Race gas a huge Intercooler will be needed. Air/air or air/water.
Race only. Air/water so you can use ICE to cool the core down.
Sucks if street driving it.
Alcohol- no Intercooler needed.
Final exhaust off the turbos. 3" to get under the truck then open up to dual 3.5" or have dual cut outs.
For me if I was to build a pure race set up.
I'd use just alcohol and deal with all that comes with the fuel.
Maintenance, draining treatment etc.
Old Sep 26, 2016 | 09:39 PM
  #30
ZO6Ted's Avatar
Is an intercooler required for E85? If not for race or street or both?
