Ordered the D1sc...Got some questions
Old Feb 19, 2010 | 04:53 PM
gao8302's Avatar
Default Ordered the D1sc...Got some questions
So i purchased a brand new D1sc setup...
-d1sc head unit (polished)
-Brackets
-Race bypass
Total: $3400 shipped
But im going to need a FMIC....What size is the biggest you can fit up front by the front bumper brackets?
What size pulley am i going to need from to hit 12# at 9.3-1 CR and mods in my sig?
What size injectors should i run? Are 60# injectors going to do it? I plan on running 15# down the road on a race tune.
Im pretty excited about this portion of the build. Ready to really crank it up on the new motor. see what she can really do.
Old Feb 19, 2010 | 05:52 PM
gao8302's Avatar
Also anyone got a suggestion on an intake manifold for this setup?
Old Feb 19, 2010 | 06:00 PM
Mangled03gmc's Avatar
Baltimore Whore
I would step up to 70's. I am not running but 9-10 psi on my 6.0, have seen IDC as high as 78%.. I will try and hunt down my ic measurements for you(can't get them now truck is burried in snow.. Mine is about as wide as you can go without cutting... a 3.8-9 pulley should get you close to 11psi( don't hold me to that should be close) Your stock intake is fine, unless you want to do a tbss, 90mm swap, or a vic jr setup.. I am running the stock truck intake now, but on the 370 it will be the vic jr, along with a 90mm TB
This is the way I mounted mine, it is pretty simple, strong, neat and effective..
Old Feb 19, 2010 | 06:24 PM
gao8302's Avatar
Cool if you could hunt down the size of the intercooler that would be awesome!!
I wonder if 96lb injectors would be over kill?
Old Feb 19, 2010 | 06:30 PM
Baltimore Whore
LMAO yah 96ers.. Just a lil bit
Old Feb 19, 2010 | 06:32 PM
Rick_Vor's Avatar
A 27x12x3or4 is the biggest you can fit between the bumper supports.
If this link gets deleted, do a search on eBay for CRXracing. i've used them a half a dozen times. They work great and fit perfect.
http://cgi.ebay.com/ebaymotors/CXRac...Q5fAccessories
Rick
Old Feb 19, 2010 | 06:37 PM
gao8302's Avatar
Rick
Thanks Rick.
I was leaning toward the 60lb injectors because i always see them for sale cheap. But i dont want to run out of injectors. I just dont see alot of people running the 70lb injectors. I figured the 96lb would be over kill and kill my idle and fuel atomization.
Old Feb 19, 2010 | 06:47 PM
kbracing96's Avatar
Originally Posted by gao8302
Thanks Rick.
The 60lbs Sema Decka (sp) everyone likes are actually 70lbs at are fuel pressure. With a return fuel system they'll fuel 800+ hp.
Old Feb 19, 2010 | 06:51 PM
gao8302's Avatar
Thats the info i was looking for thanks KB. Now just to find some
Old Feb 21, 2010 | 03:19 PM
gao8302's Avatar
Ok im going with the 27x12x3 FMIC....but how is everyone running the intercooler piping? Ill be running 3" pipe but when do you guys increase to 4" to go to the throttle body? What kind of fitting am i going to need. Im going to get a universal intercooler kit off ebay...but they have a **** load of them. I want to make sure i get all the parts needed the first time. Also i will not be running a MAF sensor so leave that out.
