On3 performance hotside only
Old Feb 23, 2014 | 03:30 PM
BUTTERB30's Avatar
NOT sure on bracing due to only getting the hotside and it came with no clamps.. but all pipes weigh about 85 pounds so it seems like some sturdy material and it looks to be 2.5 runners and and log thruout but the downpipes and rest are 3.5 or 4. THAT manifold is pretty heavy so im sure once i have the turbo added to it im gonna need to add extra bracing somewere
Old Feb 23, 2014 | 03:39 PM
timmay208's Avatar
I would suggest it, its hard to tell by the pic but looks like the same material alot of import guys use for turbo manifolds and seems like those are the ones you always see cracking or breakiing.
Places like kbracing and others use a schedule 10 or bigger pipe and weld els which are extremely strong. 850 isnt a horrible deal though
Old Feb 23, 2014 | 04:39 PM
BUTTERB30's Avatar
YEA I FIGURED id give it a try ill keep u guys posted im just waiting on a wastegate to fit this setup
Old Feb 23, 2014 | 06:51 PM
timmay208's Avatar
yea keep everyone posted on results for sure, what turbo are you going with
Old Feb 23, 2014 | 06:57 PM
BUTTERB30's Avatar
IVE GOT 70mm i bought from them about a year ago i used with a low mount set i had and ive had no problems with it,,kinda why i figured they cant be to bad.
Old Feb 23, 2014 | 10:11 PM
iDEALS1's Avatar
The hot side pipes on my kit were .090 or .098 which is a really good size. I can mic them again tomorrow to confirm the thickness. I am going to run a BW S485, but I will make a brace for the turbo regardless.
Old Feb 23, 2014 | 10:15 PM
timmay208's Avatar
Yea i was thinking it looked like around 14 gauge, good info to know
Old Mar 2, 2014 | 05:20 PM
BUTTERB30's Avatar
AS you can see i had to move the coolant jug away from the turbo because the bottom hose was touching
http://i450.photobucket.com/albums/q.../KIMG00061.jpg
SPark plug wires now touch the manifold hummm gotta figure this one out
http://i450.photobucket.com/albums/q.../KIMG00081.jpg
http://i450.photobucket.com/albums/q.../KIMG00091.jpg
top right u can see i had to cut and extend heater hose
http://i450.photobucket.com/albums/q.../KIMG00101.jpg
http://i450.photobucket.com/albums/q.../KIMG00111.jpg
http://i450.photobucket.com/albums/q.../KIMG00121.jpg
dont think ill have any down pipe issues
http://i450.photobucket.com/albums/q.../KIMG00131.jpg
ALL IN ALL everything fits like it should but u just have to move alot stuff around to keep everything off exhaust
kha4079
Oct 29, 2018 04:38 PM
mikeyjm1
17
Oct 29, 2015 11:04 PM
gaps
Oct 15, 2015 02:53 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
montecarloss
Sep 2, 2015 04:44 PM
