Oil smoke
Old Dec 20, 2014 | 01:40 PM
GRRR65GTO's Avatar
Default Oil smoke
Since I did my lifters my truck has smoked at a specific time. When Ive driven on the highway for a while and I get off to go to a gas station for example, I let it idle for a few minutes to let it cool down. Then when I go to start the truck again it will have a decent blue smoke come out the exhaust and it will continue for a few minutes once I start driving. If I just let it idle it doesnt seem to stop.
The only weird thing that I can think of happened when I did the lifters was I put my truck on my drive on lift to take the crossover off then drove it off the lift to the bay next to the lift. When I had the turbo off I saw wetness in the exhaust housing behind the wheel. So it seems like the seal leaked b/c the turbo possibly wasnt spinning?
It almost always will smoke if I get off the highway and restart it but sometimes out of the blue it will do it when I start it when the trucks hot.
Theres only so many places oil can be burned and the truck has brand new valve seals, theres no reason why the rings would all of a sudden go bad the truck has 124k on it
The turbo is an on3 76/64, can I get a seal for it or no?
Any suggestions of what else to check is appreciated thank you
Old Dec 20, 2014 | 01:47 PM
Dusty05's Avatar
How is the oil return hose routed?
Old Dec 20, 2014 | 01:54 PM
GRRR65GTO's Avatar
Straight down to the front of the oil pan basically let me see if I can find some pics
I dont have any at the moment but theres 2" peice of 1/2 pipe that comes out the bottom od the turbo to a 1/2" 45 to a hose barb to 5/8 hose to a 45 to a 2" peice of 1/2 pipe going into the front of the pan. The hose is pretty vertical I dont think I have any drain issues. Plus it smokes when its hot, when the oil is thinner and flows good
Old Dec 20, 2014 | 02:11 PM
Dusty05's Avatar
Ok. Just a thought...When I installed my turbo I had a similar situation with oil smoke and found that it was the return line (installed in front by the crank pulley). I shortened the hose a 1/2" or so, rerouted it more vertically and it solved the issue.
It sounds like your issue may be the turbo seals?
Old Dec 20, 2014 | 02:24 PM
GRRR65GTO's Avatar
Thats what I think but I dont know what to do to fix it. I was hoping I wouldnt have to throw away the turbo
Old Dec 20, 2014 | 06:19 PM
GMCtrk's Avatar
If the smoking is new, I'm guessing the turbo is shot. if the drain line was at fault, it should have smoked from the beginning I would think
Old Dec 20, 2014 | 07:06 PM
How many miles you got on that turbo? I would send them a pm and see if they could reseal it. I know others will say you get what you pay for but hey I'm running one also.
Old Dec 21, 2014 | 11:55 AM
GRRR65GTO's Avatar
I think around 10000 miles are on it
Well I didnt buy it it came with my KB kit so I have faith that Kyle knows what hes sending people
Old Jul 29, 2016 | 03:16 PM
rmill3's Avatar
Registered User
Default ON3 turbo oil return line
Does anyone have any pictures of their oil return line, I think mine may need to be rerouted. It sounds like my oil return line is in the same spot as everyone else, in front of the oil pan.
Old Jul 29, 2016 | 04:43 PM
marlboroman71818's Avatar
you said you did your lifters and that once you turn the truck off and restart it it blows blue smoke. Sounds like you may have a valve seal leaking.
