Oil line hook up..
Old Jun 28, 2011 | 06:39 PM
cwalker2006's Avatar
Default Oil line hook up..
About to install my turbo kit and was wondering where yall tapped your pan at for the return side. Pics would be nice.
Old Jun 28, 2011 | 09:38 PM
bigboy576103's Avatar
Here is where i first had mine but the nipple was to tall and hit the starter but if it were an inch shorter it would work but i ended up moving it on the right side of the bolt thats on the right of it in the pic...
Old Jun 29, 2011 | 12:33 PM
02'Z71ONDUBZ''s Avatar
If your doing it with the pan on the truck, drill the front of the pan below the crank pulley. I did mine to the right of the pulley. Make sure you dont get too low, and that you will have room for your hose and fittings around the pulley. Grease your bit and tap numerous times to catch most of the shavings. Then you can stick your finger in and wipe out any that fell onto the shelf of the pan inside. Ill see if I have a pic..
GXPJAY
Feb 13, 2022 08:15 AM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mzay
Jul 6, 2015 11:03 PM
