o2s ?
Old Aug 15, 2011 | 05:26 PM
blue0453's Avatar
Default o2s ?
Im getting a system too lean code for both 02s. Been doing it for a while. I can clear the code and it comes back eventually.. What would cause this? Bad 02s?
Old Aug 18, 2011 | 11:59 AM
Pocket's Avatar
Hook a scanner up and see if the OS2s are switching around like they should. If they are then you're really burning lean!
Old Aug 18, 2011 | 12:39 PM
03regcab sierra's Avatar
Im having the same issues its been doin it since I installed my turbo kit. Im goin to change my o2s this weekend to see if it stops or if its tuning issues.
Old Aug 18, 2011 | 05:38 PM
YenkoST's Avatar
Most likely a tuning issue and you need more fuel during closed loop operations.
Old Aug 18, 2011 | 05:47 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Low fuel pressure, vacuum leak, exhaust leak, MAF sensor failure. Those are the first things that I think about when both banks are reading lean. Also, is this a new setup, or an existing setup that has been working just fine until now?
Old Aug 18, 2011 | 05:54 PM
blue0453's Avatar
I have been running the truck on the current setup for about two years with no issues. I changes the injectors to 72lbrs and it has been throwing a code since the retune. So Im sure its tuning related but wasnt sure. I am waiting on my new wideband to get here and will be logging through hp for nelson to adjust the tune.
Will
Jul 26, 2009 11:36 AM
Chevy Cowboy
Apr 9, 2009 12:34 AM
nonnieselman
Sep 29, 2006 02:42 AM
Onyx 02
Jan 14, 2006 09:08 PM
Okie5.3
Aug 29, 2005 10:43 PM
