Is it normal to have 4-5 psi fuel pressure drop on a returnless system
Old Apr 11, 2010 | 08:10 PM
Blownme's Avatar
I plan on going up to 8 pds of boost maybe 10. But for sure 8, so from what BLownchevy is saying I should be ok. My other question is do I need bigger injectors like 60#. The one's I have are the one's that came with maggie mp112 kit.
Old Apr 13, 2010 | 02:15 AM
Blown06's Avatar
8 Second Truck Club
I used to run a returnless system on my procharged truck with 60's and a single intank 255 for 2 years. Pressure would drop to around 40-45 psi at WOT and resulted in 120+ inj. duty cycles. Now, I'm by no means saying that this is ok or ideal, however if you can keep your afr in good shape it'll work. I ran like this for 2 years without breaking any parts. Never even burned a plug.
That being said and regardless if you stay returnless or go return, I would recommend a dual intank setup and 60's. Search lonnie's or nasty fuel systems as they make turn key dual intank setups for the returnless and return style trucks.
Happy Boosting.
Old Apr 13, 2010 | 04:50 AM
MGMC's Avatar
12 Second Club
Happy Boosting.
just FYI, both of those dual set-ups require you to convert to return. You send in your sending unit and they rig it all up for a return ect... Hence the "returnless requires additional parts" on the website.
Anyone with a returnless try a single big Bosch? I figure that pump and some bigger rails/lines would be the max
I'll be converting to a return soon, all my parts should be here this week
Old Apr 13, 2010 | 03:43 PM
1BADAZZSS's Avatar
Reason I went to return is for the added room in the bucket for the twins, and the problem with trying to tune bigger high impediance injectors at a constant 60# FP @ idle on the returnless.
Old Apr 14, 2010 | 12:48 AM
marlboroman71818's Avatar
I have a bosch 040 in tank, works perfect so far
Old Apr 14, 2010 | 01:25 AM
Blown06's Avatar
8 Second Truck Club
My bad, I could have swore that I talked to them and they told me it could be done. It was a while ago, so I can't remember all the specifics.
Old Apr 14, 2010 | 12:11 PM
94 slow's Avatar
Originally Posted by BlownChevy
10 psi.......I do have a pump in the tank, as I can only assume the OP does as well.
Brian,
Is your fuel system similar to a dead head system?
Old Apr 14, 2010 | 12:50 PM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by 94 slow
Brian,
affirmative.
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
slowlsx
Jul 13, 2015 04:18 AM
