NNBS Whipple Install
#81
I was wondering if you tow anything , and what you noticed if you did.
#82
#83
The trans is actually not too bad after a few runs. Nothing as bas as towing the boat around, but now with the supercharger the temps are likely to rise a bit more. I'll be towing the boat again in about a month from now to get some work done to it and I'll see if I can remember to get some temps for it.
#84
Should be at the Baytown track tonight for some test and tune.
We finished up going to the smaller pulley last night, some 55# injectors from a Shelby, and the GM 2Bar cobalt sensor. Last night we just got the tune to where it was drivable and we'll be working on it at the track to get the shift points in the right place and get all the bugs worked out of the tune.
I'll be running it in full street trim with the 22" wheels and at least a half tank of gas or more so I won't be expecting much for stellar times but hope to see a 12 second pass. Last time out it was around a 13.2 with some tune problems and letting out of it slightly. Now with the fresh tune being created at the track and a little more boost it should be running much better.
#87
60' = 1.911
1/8 = 8.262 @ 85.81
1/4 = 12.896 @ 105.19
Full weight, 1/4 tank of gas, 22" wheels, and running nothing but hot laps to get the tune worked out. Truck runs perfect with a safe 11.7 AFR. It is clear the truck has more left in it, but I am happy with where it sits now as my daily driver and occasional boat mover...
Next time I go out I'll put on the 18" wheels and let the motor cool off for a couple hours before making any passes. I'll also be looking into a stall converter to see about getting it off the line a little better, but I am in no rush for that.
1/8 = 8.262 @ 85.81
#88
Great times!!!
How much boost were you running on that pass? Any idea what kind of power your making?
60' = 1.911
1/8 = 8.262 @ 85.81
1/8 = 8.262 @ 85.81
