NNBS Whipple Install
Old Nov 8, 2010 | 12:43 PM
  #41
bdubb's Avatar
Originally Posted by gonzo 6.0
do you feel your scan gauge has been accurate in the past?
This is the first time I have used it for the times like this. It bases itself off of first movement of the vehicle and then however long it takes to get to the 1/4 mile distance. Assuming the tire diameter is close and there is no spinning of the tires it should be fairly close.
Old Nov 10, 2010 | 12:30 AM
  #42
gonzo 6.2's Avatar
You making head way on that machine???
Old Nov 10, 2010 | 10:29 AM
  #43
bdubb's Avatar
The custom tune is done and I should be getting a boost reading tonight. Then I am just waiting on Friday night for some time at the 1/4 mile track.
I'll be ordering injectors, pulley, & 2 bar map after we see what boost I am starting off with tonight. I'll pulley down to get to 8 PSI and then be done with it for a while.
Going to go with one of the Trick battery tray tanks as well. I'm not a fan of the look on the placement with the stock Whipple coolant tank.
Old Nov 11, 2010 | 08:25 AM
  #44
bdubb's Avatar
Not sure the weather is going to allow any track time this weekend, but I found out my boost level finally.
With the stock supplied Whipple 3.625" pulley and on a stock L92 motor with 1-7/8" headers and Corsa catback I am seeing right at 6 PSI at WOT. Normal cruising and light acceleration it's at 3 PSI.
Old Nov 11, 2010 | 09:32 AM
  #45
gonzo 6.2's Avatar
I submit to you a request to vid the dash for a simulated 1320ft run.thank you
Old Nov 11, 2010 | 10:15 AM
  #46
bdubb's Avatar
Sounds like a plan. I'll try for that this evening if it is not raining.
I'll try to get one with the scan guage too so we can compare against it.
Old Nov 12, 2010 | 04:47 PM
  #47
bdubb's Avatar
Well, going to make my way back to the drag strip for the first time in 3 or more years.
Despite the scan gauge photos above, place your bets now on the results of the kit. Going to run with the heavy *** 22" wheels and tires and likely about 3/4 to 1/2 a tank of gas. Full street trim.
Truck is at 6PSI with the stock L92, GMPP intake, ARH 1-7/8" headers, Corsa Touring catback, custom tune.
Old Nov 12, 2010 | 07:25 PM
  #48
gonzo 6.2's Avatar
12.8 105mph
Old Nov 12, 2010 | 09:06 PM
  #49
bdubb's Avatar
13.3 letting off. Sounded like it was detonating and was spiking rich to 10.0 afr
Old Nov 13, 2010 | 12:16 AM
  #50
bdubb's Avatar
Couldn't get better than a high 13.2 at 101 mph with a flared 3-4 shift . The tune needs some more work.
I think at 6 PSI, and some more things going my way along with stock wheels a 13.0 is within reach, but I don't see 12's happening without going to 8 PSI with this heavy truck. The RCSB trucks would be killer though with this setup I think.
