NNBS Whipple Install
#31
Well, not the full update that I wanted but I have some updates nonetheless.
I didn't get a chance to make it to the track this weekend and will have to wait until Friday if I am lucky enough to still be home at that point. (Busy year with business)
I did however get the exhaust tips for the Corsa system raised and welded into a more appealing location, got an O2 bung welded in, did a temporary install of a DynoJet WB2, and got HPTuners all lined out along with a new tune. There are no dynoes to my knowledge in the Houston area that will fit my AWD truck, so we had to do a street tune and get it the best we could before running into issues with the local police. The first thing I have to say is that the custom tune made a HUGE difference. The surge around 1800 rpm is gone, the tune was leaned out a bit from the whipple handheld pre tune, and everything else in general just improved a great deal.
With my tires 305/40-r22 Parada Spec-x at 31.75" diameter and the computer set to the same I did two passes trying to get a ballpark result with the AeroForce scan gauge. The results are below. You will notice I had to let off on the second run.
If these times are anywhere near close I am going to be VERY happy with an official timesheet in the mid 12's while still having on my heavy @ss chome 22" wheels. Keep an eye on the thread as I still need to get a boost reading (Guessing I'm around 5 to 6 psi) and if all goes well I'll have some true 1/4 mile times by Friday evening.
#32
Forgot to mention, that the Whipple supplied 46# injectors are at 102% at the 1-2 shift and down to around 97% for the other shifts. I will be upgrading to some 60# injectors, 2 bar map, and bringing the boost up to 8 PSI around the end of the year. The only delay will be trying to save my trans until March of 2011 if at all possible, I've spent enough this year.
#33
Nice first testing,cant wait to see what all gets done by friday,great job thanks for sharing.If you get to the track friday do you plan to run the big wheel/tire? You must be thinking this could crack 11s someday if your testing is accurate
#34
I am considering putting on the stock 18's and crappy stock tires. I am also curious what it would do in full street trim though. I'll mull it over during the week and see.
I am not chasing times for me or the truck, but I think a lot of others are curious what the whipple will do so it puts me in 50/50 spot right now.
#36
#37
