NNBS Flex Fuel pumps hit or miss???
Old Aug 26, 2014 | 03:37 PM
kazfan30's Avatar
Default NNBS Flex Fuel pumps hit or miss???
Just kinda curious on everyone's experience here...seems as if one person is hitting 550-600rwhp on one and big boost, then i read another post about one maxing out at like 450rwhp and 7-8 psi.. ? I figure if magnacharger and some other manufacturers trust them enough to not supply in a kit they must be pretty stout...
Whats your experience??
Old Aug 26, 2014 | 05:48 PM
Jake75's Avatar
mine was maxed out on 7lbs of boost and my maf was getting close to being maxed. I went ahead and put a walbro 450 100lb injectors and ordered a 3 bar map so i can get a speed density. if your gunna go more than 10lbs might as well do the upgrades before u get tuned
Old Aug 26, 2014 | 06:21 PM
Turbo09's Avatar
From what I have seen, heard and experienced. They are good to 550-600whp 12psi ish my non flex pump was good to 5psi that was all.
Old Aug 26, 2014 | 07:26 PM
kazfan30's Avatar
Well I had a big walbro in my old 2003 5.3 and 60#s running 15 psi...but im about to throw a small cam and heads on my ccsb.. and thought about a p1sc. Done the turbo route years ago and want a more bolt on and done approach these days lol.
Old Aug 26, 2014 | 08:11 PM
bud8fan's Avatar
mine in the '11 is holding up great
Old Aug 27, 2014 | 12:35 PM
kazfan30's Avatar
Guess i can only try and see what happens....maybe ill be one of the lucky ones?
Old Aug 27, 2014 | 12:45 PM
Jake75's Avatar
I think u will be fine I think more than anything my flex fuel injectors where being maxed out not necessarily the pump I just changed it to avoid problems with higher boost
Old Aug 27, 2014 | 01:35 PM
kazfan30's Avatar
OHHH ok....yeah i definitely was going to change injectors...just didnt want to have to put a pump in it....lol
Old Aug 27, 2014 | 02:50 PM
Choda's Avatar
I have the stock Flex pump with black ops 60 lbers and 12 psi. Works fine
Old Aug 27, 2014 | 03:23 PM
kazfan30's Avatar
Thats the route i was going Choda, stock Flex pump..60's and about 10-12 psi on a maggie or p1sc.
