View Poll Results: Front mount rear mount or N20
Voters: 36. You may not vote on this poll
nitrous or turbo?
#22
Yeah Ive been looking into 80E and th400 swaps already. I will most likely need a rear end too correct? I was thinking 12 bolt swap to hold up to the boosted power.
are there any other turbo kit companies I should check out? as of now im still liking the trick kit.
Ill look into isky cams, I have heard really good things about them for boosted and N/A applications, thanks again!
If you look around on here, my kits are quite popular
#23
Who are you??
just kidding.. ive seen ole kyles kits and they arent all that shabby, im saving up my pennys for one.. they will get you where you wanna go.
ive seen some of his kits in the 9s
for a cam in the 5.3 check out the isky triple 12. makes a good bit of low end and in boost its perfect. idle is bout perfect, its not choppy but its not quiet as stock.
an 80e and a good rear differential will get you in the 11s if thats plenty enough..
also nitrous on top of boost is pretty crazy
the jet size i was running came out to be a 47 shot, which dont sound like much but it added 60rwhp and 90rwtq on just 6psi with a stock lq4.
#24
KBRacing96, I have read a lot of GREAT reviews about your kits and was on your site the other day. But now I cant find it
any chance you could post a link because honestly its between you and trick unless someone can find another kit with kick *** reviews and a lower price! either way ill keep looking for your site in the mean time.
I actually like the idea of a small shot on top of the boost, I know a couple of guys using nitrous to spool faster. obviously these are racing/high power applications, higher then what I will be running for sure, but it still would be cool!
really liking all the great ideas and responses guys! thanks again!!
any chance you could post a link because honestly its between you and trick unless someone can find another kit with kick *** reviews and a lower price! either way ill keep looking for your site in the mean time. I actually like the idea of a small shot on top of the boost, I know a couple of guys using nitrous to spool faster. obviously these are racing/high power applications, higher then what I will be running for sure, but it still would be cool!
mz00516
Aug 23, 2015 12:19 PM
