Newbie boost question
Old Feb 20, 2014 | 11:36 AM
BigDaddy0381's Avatar
Default Newbie boost question
I know nothing about a turbo nor never really cared much about them but I just got an offer I can't turn down, I don't think. he is going to donate most everything and all the work to build the kit and install it for basically free. I just have to do a show and tell for him.
now my question is on my 6.0 at a 10.8.1 CR ( specs below) would 8 to 10 pounds of boost make me run out of injectors (flex fuel) and the stock fuel pump? also I'm guessing my set up wouldn't be bad but not the best for boost? or do you think it would be. I don't want nothing in the high boost range just something lowish.
any thoughts will help.
Old Feb 20, 2014 | 11:45 AM
Byrdman11's Avatar
Pump= No injector= maybe with less boost.
Old Feb 20, 2014 | 04:25 PM
GRRR65GTO's Avatar
Youre gonna need a fuel pump regardless and its honestly not bad putting one in. A walbro 400 is around $100 and will get you where you need to go. Im no expert but I dont think your flex fuel injectors will be big enough for 8-10 lbs. 60s will do that just fine
Old Feb 20, 2014 | 06:48 PM
is there a drop in no hassle walbro 400 fuel pump and wiring out for this truck now? what injectors do you recommend?
Old Feb 20, 2014 | 09:48 PM
GRRR65GTO's Avatar
The injectors im running I bought after i found out about the bad reviews but its too late for me so I hope theyll work.
This is the same for the 400
https://www.performancetrucks.net/fo...ite-up-465754/
Heres the few pictures i took of mine, I ran 12 gauge wire to my pump
1389146826003_zps7c11b976.jpg?t=1389929442
2014-01-07210644_zps657ed2db.jpg?t=1389929460
GXPJAY
Feb 13, 2022 08:15 AM
89sierra
Aug 19, 2015 07:13 PM
USMCvet0311
Aug 1, 2015 07:45 AM
