New Truck!
Old Jun 2, 2008 | 12:01 PM
dan96z71's Avatar
Keep your options open. Don't count out the radix as that thing gets these big trucks moving very quickly.
Old Jun 2, 2008 | 12:03 PM
fastnblu's Avatar
Originally Posted by 2005 Silverado
Radix not that good of potential? There are some 11 and 12 second trucks with radix's and bolt ons. So not that good of potential is BS IMO.
Dustin
+1.HHHUUUHHH!!!??? A Radix is a nice piece. Even a turbo has something u might not like. More tuning req., bla bla, search or just look @ sticky under FI. Pros & cons to both. Arm yourself w/ knowledge 1st, then decide.
Originally Posted by ryan_prettyman
On a stock 5.3 is not that good, and also you have belt slippage, I work with a bunch of GTP guys they all swiched to turbo's because they couldn't break 11's and also had slippage problems! And even if you have a built engine you can only get so much boost with an eaton, turbo's are more efficient they don't use horsepower!
Everything has limits.
Originally Posted by 00ChevyScott
are you wanting a street truck or a track truck?
Both would be great I think I would be done once I get into the 10's or 11's!
U want both? Both what? Street & Track?
Originally Posted by yurs78
Having a 10 second daily driver is a breakdown waiting to happen no matter what you're using. You'll spill your stock bottom end or blow your tranny all over the road in less than 20,000 miles.
To run those times with as much reliability as possible you'd better have atleast $12,000 sitting around waiting to be spent.
Anything is possible but it's not cheap.
Agreed.
Originally Posted by Maroon20's.
There's several people on here FI w/ the 5.3. Trever come to mind when i think of them, he is in the 11's, but he is supercharged. It is attainable, but you have to pay to play. More horsepower and you may have to uprgade your rearend, transmission,and driveline. There's sponsors on the right>> for all of that. Fuel system is another must if your looking for 500rwhp. The sponsors i can think of that sell front mounts are:
TrickPerformance
kbracing
Nelson
If im missing somebody, please correct me. Good luck on your project, and ask just ask questions, it may save you from alot of hassle.
+1. Nelson too? I wasn't sure if he did 1, but I read so much, I forget sometimes.
Old Jun 2, 2008 | 12:14 PM
TrickTurbo's Avatar
Truck Sponsor
I just bought a 2006 silverado with the 5.3 auto I have had it about a month and I have already put silverado ss wheels, flowmaster exauste, beltech, and a hypertech powerpac on it, but I am looking for some serious power adder it seems as though all you guys have turbo kits, I do like the Radix but I don't think they have that good of a potential so I might go with the turbo let me know what the best kits are because I don't want a homemade kit I would like to make 500 rwhp, and keep in mind this is a low mile truck all stock so I have to keep it nice thinks!
500 is doable with our stock kit turning the boost up to around 12psi. There is a huge difference is 10' or 11's.
Tranny is usually the first thing to go south. So you might check into a different unit there.
The thing I like about turboing these trucks the systems can grow with you over time.
You can install an INTRO kit, and leave the boost at 6psi and have some fun for awhile, a day or two. LOL Then when you are ready to do a tranny swap start turning the wick up.
If you want more or plan on going to a larger engine then the Street Stalker maybe what you are looking for. We will build the kit around your final goals..
Now keep in mind our kits are for off road use only, and you will have to build or have built the final exhaust connection.
let me know if there is anything I can do for you.
Rick
Old Jun 2, 2008 | 12:55 PM
kbracing96's Avatar
I also sell a turbo hot parts only kit if you are some what of a do-it-yourselfer. It's the same hot parts I have on my 4.8 and it makes 500 hp in high boost (11psi). Let me know if this might be something your looking for.
Old Jun 2, 2008 | 02:11 PM
WJ MARK's Avatar
Nelson carries The Trick Kit
Old Jun 2, 2008 | 02:17 PM
fastnblu's Avatar
Gotcha! Are those any good WJ?
Old Jun 2, 2008 | 05:29 PM
WJ MARK's Avatar
If I was to do it again I would run the turbo and a Radix, lol.
Old Jun 3, 2008 | 01:01 PM
jleonard711's Avatar
Wow, that's one hell of a run-on sentence!!
In addition to what others have mentioned, you might want to look at an STS turbo kit as well. That kit uses a remote turbo mounting system so the turbo isn't up in the engine bay heating things up. And it's a very simple do-it-yourself installation too, because the turbo just mounts in place of your muffler and then you run a return charge pipe back up to the engine, so you don't need to mess with pulling of the headers or anything like that.
You could also get a new cam to boost your power a little. A good cam will run you around $300-$400, and you will usually see at least 30-40hp when adding a cam to a boosted application.
But if you're looking to make 500+ at the wheels, you'd be better of swapping out the tranny before you even touch the engine. Hell, my tranmission failed on my after just getting a custom Wester's tune (which included removing the TM and slightly boosting the line pressure).
Old Jun 3, 2008 | 02:31 PM
nonnieselman's Avatar
Built 4L80E should be your first mod, and sell all the "mods"(Flowmaster& hypercrapper) on it you have now and start doin alot of research.... Your goin to need it.
and good luck, hope your wallet is deep..
Old Jun 4, 2008 | 07:09 AM
8ALTNG's Avatar
Oh boy......let the **** talk, data sheets and bashing begin
