new times with the meth! got questions.
Old May 15, 2007 | 04:48 PM
i believe he set the sensitivity pretty high? and i am running 93 octane plus the meth, which raises the octane significantly. and i havnt ran into any knock yet. so i dont know. is there a way to tell if the knock sensors are working right?
Old May 15, 2007 | 05:08 PM
bud8fan's Avatar
Originally Posted by KBOBOZ71
my iats are around 120 when i launch and climb to around 158, by the end of the 1/4. and yes 27* is correct. ive heard that when tuning for meth that you need to start by adding 9* and go as high as 15*. is this correct? we've only added 8* so far, but we were scared to add anymore. can anyone tell me about how much theyve been adding with the meth. mine is a 50/50 mix.
my max timing was 26* with meth/water and my iat's were just like yours are now...i could not go any higher with the timing....congrats by the way!!!!
Old May 15, 2007 | 08:23 PM
Wilde Racing's Avatar
How do I change this text
I would NEVER EVER add more than 2-3 advance at a time......
parish8's Avatar
single digit dreamer
i wouldn't go over 20deg. there is more power in boost than timing, quite a bit more. if you want to tune to the limit of your fuel(fuel and meth) keep your timing moderate(14-18dedg??) and turn up the boost till you start to see some knock. then back it off a couple psi.
only reason to push the timing is if your out of compresor and want to wring out every last hp. hmm. just saw you have a mp112. you might be running out of air but i still wouldn't go over 20deg of timing.
Old May 15, 2007 | 09:25 PM
Allgonoshow's Avatar
what he said[parish]
those are awesome times and job well done
5.3Caprice
Nov 7, 2015 08:56 PM
hartinclay
Aug 2, 2015 06:44 PM
tim wellington
Jul 31, 2015 03:28 PM
