New Set up - what do you think
Old May 12, 2010 | 04:00 AM
Spoolin's Avatar
GFYS and STFU
Old May 12, 2010 | 10:01 AM
Just install a carb on it... Jfwu
Old May 12, 2010 | 10:05 AM
WJ MARK's Avatar
I think the LS6 would work pretty well, The vic. jr. I believe make more power up top.
Old May 23, 2010 | 10:16 PM
tarinitup's Avatar
9 Second Truck Club
Machine shop found a hairline crack on one piston so now I'm shooting for 9 to 1 compression and run a little more boost. Keeping the vic jr and will use stock throttle body.
Old May 24, 2010 | 11:44 AM
FarmTruc's Avatar
Performance Trucks Sponsor
Originally Posted by tarinitup
...and will use stock throttle body.
my 408 TT, low compression, stock heads, stock truck intake, stock throttle body gave me 800+hp, i think your setup will be fine.
Old May 27, 2010 | 10:37 PM
fastrt's Avatar
11 Second Truck Club
damn!
to the op, what about the new pro flow xt thingamabopper? it looks good to. or keep your vic jr. either way it will make great power!
Old May 28, 2010 | 12:22 AM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
My 408
How much power should it make if it made 750rwhp on 15 lbs with stock heads and 9.5 compression?
first off i'm not hating but just asking
408ci/9.5:1/91mm turbo/15lbs of boost only produced 750rwhp??
my SVT Lightning was
331ci/8.9:1/76mm turbo/19lbs of boost made 719rwhp....
is that an average HP of a 408ci and 91mm if so honestly i wll not be happy with my build
Old May 28, 2010 | 07:11 AM
tarinitup's Avatar
9 Second Truck Club
I don't feel like my truck ever reached it's full potential either. Something always went wrong at the track or dyno. The new engine will end up 9.5 again and keeping the same set-turbo so we will see what it's capable of. I can tell you that I tried the truck at 18psi with more timing and it made 15lbs feel slow. I'm sure had my 4" flex connector not restricted the exhuast to 2" and all of my spark plug wires been tied it it would have been a different story.
Old May 28, 2010 | 07:12 AM
tarinitup's Avatar
9 Second Truck Club
Originally Posted by Blown06
Casey: 3
Allen: 3
I've got y'all tied up. This is gonna be a close one!
To the OP: I've always had the stock DBW 78mm on my truck. Not sure how much power it made in the end but I have a dyno sheet that shows 700rwhp at 6000 rpm and pointing straight up. I'd say get it running on the 78mm and go from there. You can always upgrade later.
Thanks I already bought the adapter to use it.
Old May 28, 2010 | 09:36 AM
BlackGMC's Avatar
Resident Retard
Well, I cleaned up the thread, lets try to keep it on topic guys...
