New Radix...some disapointment.
Old May 25, 2006 | 10:00 PM
Scott Mills's Avatar
Default New Radix...some disapointment.
Well I got my Radix installed. I bought it as a used kit from a board member and the install went great. I had to buy a few missing pieces, but it was easy to get all the parts from Magnacharger. I am not using the stock tuner, because it was a used kit and Magna wanted $300 clams for the box. I already had a freepass with Nelson's so I am using his tuning. The truck runs great and I believe that the truck is safe in the tuning. I am a little disapointed in the performance though compared to my old STS kit. It just does not feel like the same level of performance. I am currently seeing about 5 to 6 psi from the radix. I measured the pulley and I believe that its a 3.1 or 3.2 which I think came stock with this hummer kit. Is the tuning off? or is this the performance you get from a stock kit? I have some logs Ive taken with my EFI Live, but I realy dont know what I am looking at. Any thoughts? Please don't say use the stock tuner as there isn't one.
File Type: zip
Old May 25, 2006 | 10:07 PM
Charged_5.3's Avatar
Get the J-Tube with the LS2 throttlebody and a GT2-3 Cam. Seems to be working for everybody that has a Radix.
Old May 25, 2006 | 10:32 PM
You should be seeing more boost check for vaccuum leaks.
Old May 25, 2006 | 10:40 PM
Mr. Sandog's Avatar
Had you ridden in a vehicle with a Radix before buying yours? Realize that roots SC boost feels different than turbo boost. The Radix comes on right away and is steady after that. It can be deceptive, simply because once it comes on line, it can appear flat.
This is different than how turbo boost comes on - very slowly, then as you get further up the RPM band, the boost increases, creating a feeling of more and more power the more you apply throttle. Different feeling altogether IMO. I wonder if this is part of the issue.
Old May 26, 2006 | 05:00 AM
thunder550's Avatar
High on diesel fumes
My 3" pulley on my LQ9 nets about 7psi, so his numbers sound about right....
Old May 26, 2006 | 05:04 AM
TurboGibbs's Avatar
I wasn't really impressed with my Radix until I started pushing at least 10lbs boost.
Old May 26, 2006 | 06:30 AM
dewmanshu's Avatar
Moderately Differentiated
Yep, SOMP Gauge is being fooled.
Old May 26, 2006 | 07:41 AM
Yes I was wondering if I am just being fooled by the power. I am planning on getting it on the dyno for a tune next month at Nelsons. I also have an LS6 cam and springs for it. I'll go to a 3.00 pulley then as well.
