New Radix Install pulling a code?
A new Radix install (purchased LoudAzzLowStepside's kit) on a 2006 Flex-Fuel 5.3 Suburban is pulling a MAF curcuit signal low code (check engine light is on)? The instructions say to splice into the MAF wiring (the black and tan wires), which I did. There is also a black with white stripe wire, did I use the wrong black wire? Magnusson told me Black and Tan today, but couldn't help with the code? Used Bryan @PCMsforLess tuning, and runs good and pulls hard otherwise.
Any help would be appreiciated. Thanks!
what is the actual code? If you have a signal low code, more than likely you have the wrong ground cut.....Please post up a picture of the MAF plug and the wires you cut.
But kit was from a 2004 as you know, so does the 2006 have a different ground? maybe the Black with white stripe wire? Can I hurt anything by trying it? Can that sensor with two white wires (that I'm splicing into) be bad and be popping the code? I will try and post some pics later. Thanks
ARC
57
Feb 21, 2022 10:54 AM
lsxperformance
Aug 2, 2015 10:08 AM
therock
Jul 25, 2015 09:23 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
