New heads...how to tie them down
I'm adding some 243 LS2/6 heads to my LQ4 with an MP122 Radix on top. Compression should go up about a pt. or a little more. What should I use for head bolts/studs? Boost is about 9 psi.
Most tq them about 10lbft over stock with f/i... Same tq sequence.
The GM gaskets seal as good or better than cometics and are more forgiving on the cleanliness of the the deck/head... I know there are sevral very high boost/hp setups with stock gaskets. They come in 3 layer or 5 layer if I'm not mistaken.
Do not lock-tite the studs, they go in until they bottom out hand tight only! As far as I know ARP studs are reusable and do not use the stock Torque-to-yield method. The instruction in the stud box say that you torque them to 23ftlbs - I question this! What has everyone on this sight torqued theirs too?
