In Need of some Major help guys!
Old Sep 17, 2016 | 01:46 PM
  #21
2ToNe04's Avatar
Originally Posted by JordanH
How can it be pegging out the MAF, if it wasn't seeing any boost? It's not going to be the MAF that's restricting anyways, it's going to be the tubing size that it's in. With that said, I'm pretty sure the later years gmt900 were easier/better at tuning with boost. You may need to find another tuner! But I know the truck shouldn't run like that regardless, especially on the stock tune with the stock MAF, ffpump, and injectors in it. If you do all that stuff I said, it should run fine and make boost, Regardless of tuning.
Thank you very much ima take your word for it and begin putting everything back.
Ive been researching the MAF and it semi makes sense that it might be getting pegged. I seen on the camaro forums guys talking about a weak and a strong MAF too, maybe this autozone MAF was poorly built.
Any thoughts on this?
"Weak" vs "Strong" Camaro SS MAF Sensors - Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com
$210
http://www.pmas-maf.com/product/hpx/
Old Sep 17, 2016 | 07:14 PM
  #22
BlackGMC's Avatar
Resident Retard
Buy a acdelco maf.
Old Sep 19, 2016 | 08:38 AM
  #23
GRRR65GTO's Avatar
Do you have a wideband like mentioned before? If not not you are asking to blow up your motor because you have no idea what the air fuel is
Old Sep 19, 2016 | 04:02 PM
  #24
2ToNe04's Avatar
yeah i have the wide band on, but its in a good okay range for now, i think the maf is throwing it out of whack.
But i placed my order on the GM PMAS MAF, it was a little pricey, but hopefully itll fix the situation, if not onto putting stock components back on
Old Sep 19, 2016 | 04:19 PM
  #25
Atomic's Avatar
I have a gauge for that
Motor is way way rich, I can tell just by hearing it. Your MAF is not working correctly. Find a new tuner that will tune it 2bar SD (I can help you if you have hptuners). No need to keep the MAF on these trucks with boost, more trouble than its worth. MAFs have their place, just not with this.
Old Sep 19, 2016 | 06:00 PM
  #26
JordanH's Avatar
Restricted
I was under the impression that on the gmt800 SD is the way to go, but on the gmt900 that keeping the MAF was a good thing? Maybe just on the 07-08 models?
Old Sep 19, 2016 | 06:52 PM
  #27
FFDP's Avatar
Yeah GMT-800's it's SD if you want boost. The GMT-900's can use the MAF just fine with a 2 bar map sensor for boost.
Old Sep 19, 2016 | 07:43 PM
  #28
2ToNe04's Avatar
I wish there was more tuners available in my area. I already paid the place too.
I think with the amount of money spent on the dyno tune, trips there, and buying a new MAF i could have purchased HP tuners, and conservatively tuned it myself.
A refund doesnt sound like a bad idea right now.
Old Sep 19, 2016 | 09:44 PM
  #29
Atomic's Avatar
I missed where this was a 2011, thought it was the one in your sig. Same thing applies though, it's way rich. Your stock MAF should be ok but you need a 2bar sensor in there. Your issues are tune related.
Atomic
Oct 20, 2016 12:47 PM
gearhead 69
Jul 6, 2016 07:13 PM
Austin Schiestel
Jul 2, 2016 09:37 PM
A4edwin
Jul 2, 2016 12:13 AM
XL7
Jun 26, 2016 05:36 PM
