Silverado SS miss fire problem
Old Jun 27, 2016 | 05:12 AM
Austin Schiestel's Avatar
Registered User
Default Silverado SS miss fire problem
Hey guys !
I am at wits end with this truck. I'm working on a 2003 Silverado SS and I have built a 408 stroker for it and ever since I installed it is have had it sputtering and miss firing between 2700 and 3800 rpm. It is not a tuning issue nor is it a vacuum leak. All the plugs look the same when I pull them and all the coils are brand new. I have 2 small grounds on the back of the engine + the body strap, and one small ground on the front. New cam sensor , new battery , new alternator , new spark plug wires. The only code I am getting is a P0101 ( mass air flow out of range ) , I also have an ls7 maf and the proper tune for it. The truck also runs worse when I have any electrical load on it (heat, air, electric fans, ect). Any ideas or insight would be much appreciated!
Old Jun 27, 2016 | 05:29 AM
Registered User
If anyone has any other questions please ask!
Old Jun 27, 2016 | 10:03 AM
Atomic's Avatar
I have a gauge for that
Dont rule out a tuning issue.
Do you have hptuners or efilive where you can post a log file? That would be most helpful.
Right off the bat try the stock MAF with a stock MAF curve in there to see if it gets you close.
Old Jun 27, 2016 | 11:09 AM
Registered User
Using efi live and I don't have a file I can post unfortunatly. I have tried different ls7 mafs but not the stock one, seemed like a lot of trouble for something that may not work
Old Jun 27, 2016 | 11:42 AM
Atomic's Avatar
I have a feeling thats the source of your problem. If this is a NA setup the stock MAF will be more than enough anyway.
Old Jun 27, 2016 | 01:11 PM
Registered User
Do you know off hand if an ls7 maf is the same as an ls3? Might be my issue right there
Old Jun 27, 2016 | 01:20 PM
Atomic's Avatar
I dont know off hand
Old Jun 28, 2016 | 07:37 AM
Registered User
I'm wondering now too if my MAF sensor is maybe too close to the filter and is picking up turbulence, sounds like I have a few things to try this weekend
Old Jul 2, 2016 | 09:37 PM
Registered User
Well I moved my sensor farther down the tube , bought a new maf too and still no luck .. I don't have the ability to re-tune at the moment so I can't try the stock maf. I'm wondering if there is a grounding issue still ...
About20ninj45
May 5, 2023 07:49 PM
09CamdSilvy
Apr 17, 2016 09:17 PM
09CamdSilvy
Mar 2, 2016 09:47 AM
Jason 98 TA
Jan 26, 2002 01:08 AM
