Need Oil Pressure Restriction
Old 09-24-2010, 06:57 PM
Ender06's Avatar
Default Need Oil Pressure Restriction
OK, I have oil draining into the turbo after it sits for a while. What do I use to restrict the oil to the turbo? Ive heard people say check valves and nitrous jets but which ones? I need something from like napa that I dont have to order and wait on. Its a rear mount system with a -4an line to it.
Old 09-24-2010, 08:18 PM
kbracing96's Avatar
You need a check valve with like a 1 psi cracking pressure. I'm not sure where you would get one locally, I've always gotten them from mcmaster.com.
Old 09-24-2010, 09:16 PM
Formerly darynC-10/23/10
Daryn's Avatar
mcmaster has alot of helpful stuff... if you cant find it on the site , give them a call and they can help you out
Old 09-24-2010, 09:18 PM
Ender06's Avatar
OK, im looking right now. Can I find one that fits the 4an hose or will I need pieces to make it fit?
Old 09-24-2010, 09:19 PM
Ender06's Avatar
And also, Im getting oil in the intake as fast as I am fuel...is this from the oil sitting in the turbo? too much oil?
Old 09-24-2010, 10:39 PM
SLO TRUCK's Avatar
Nope thats more likely blow-by. Do you have a catch can set up or the valve covers vented.
Old 09-24-2010, 11:43 PM
Ender06's Avatar
Not yet...but Im loosing oil like crazy. What do you mean by blow-by?
Old 09-24-2010, 11:45 PM
Ender06's Avatar
Its definetly coming from the turbo. It smokes like crazy when I start it up after sitting a few minutes.
Old 09-25-2010, 12:22 AM
SLO TRUCK's Avatar
Well if your sure its from the turbo that is better. Blow by is when you crankcase pressure is pushing oil and it ends up in the intake sometimes.
Old 09-25-2010, 12:24 AM
Ender06's Avatar
OK, Im cleared up on that. What exactly is causing the turbo to use so much oil? Would the check valve possibly clear it all up? It smokes bad, even if I just stop for about 10 seconds sometime. Its strange
Quick Reply: Need Oil Pressure Restriction
