need more fuel !!!
Old Jan 7, 2012 | 11:54 AM
MHSLOT12's Avatar
Default need more fuel !!!
hi guys - i have a 2004 5.3L silverado 4x4 with a pro charger p-1sc 8lbs boost & 44lb injectors . engine is running very lean & i know that I could burn a piston if i don't get more fuel. so i'd like to put in a areomotive 340 in tank pump to get the fuel I need . but witch one do i use & how do you install the pump i don't think they come with instuction LOL .and one last thing . i have a returnless fuel system .putting in this new pump will give more fuel .what happens if it makes too much fuel ?? where does it go ? it my seem like a stupid question . i'd just like to know before going though with it ! any info or pictures will be a great help
thanks
Old Jan 7, 2012 | 11:11 PM
05_quick4door's Avatar
The regulator is in the tank module. It should bypass enough at times of low fuel consumption. As far as instructions im not a full size guy but I shoe horned 2 walbro 255s in a colorado with minimal drama and no instructions
Old Jan 7, 2012 | 11:28 PM
sik-rod-dog's Avatar
two things you can buy one is a kenne bell boost a pump or meth
Old Jan 9, 2012 | 10:54 PM
4.8whipple's Avatar
i did the walbro 255 and i love it. easy install and it does what i need
Old Jan 9, 2012 | 11:07 PM
jgb454ss's Avatar
I used the center in center out, and it is just as easy as the walbro to install. I would suggest to make it return style with boost reference, since u have a procharger.
Old Jan 10, 2012 | 12:07 PM
MHSLOT12's Avatar
great advice -thanks to all of you ! it's going to take a while to get the setup in. but I will let you know what happens... thanx
Fast86z
Aug 23, 2015 12:35 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
jrplz
Jul 9, 2015 12:07 AM
