"Need help Turbocharged Silverado Sputtering"
Old Jun 18, 2016 | 07:07 AM
josegbnl01's Avatar
Default "Need help Turbocharged Silverado Sputtering"
Need help 2014 silverado with turbo,cam,meth its been sputtering at wot checked all my plugs and wires seems they are ok plugs are gapped at .040, after a pull my check engine light starts flashing for about 3 minutes wideband reads 11.0-11.6 wot 25-90mph pull sometimes it drops to 10.7-10.90, after 90mph it jumps to 12.0-12.6 and then really runs like **** any help will be appreciated
Old Jun 18, 2016 | 07:22 AM
Jeepplr's Avatar
Think it could be too much meth? Is it meth/water?
Old Jun 18, 2016 | 08:31 AM
Atomic's Avatar
I have a gauge for that
It's misfiring. Tighten the plugs to 0.028 and make absolutely sure the wires aren't touching a header pipe.
Old Jun 18, 2016 | 09:18 AM
03sierraslt's Avatar
Meth doesn't like large plug gaps.
Old Jun 18, 2016 | 10:18 AM
josegbnl01's Avatar
Im closing the gap to .032 se if that fixes the problem, wires have heat sleeves on them
Old Jun 18, 2016 | 10:28 AM
Atomic's Avatar
I would go ahead and go to 0.028, youll end up there anyway.
Even if they have sleeves, make sure they are not touching. I burned wires through double wrapped exhaust and double sleeved wires, it can happen.
Old Jun 18, 2016 | 11:52 AM
05GMC4.8's Avatar
make sure you dont have any exhaust leaks up stream of the o2/wideband sensors too
Old Jun 18, 2016 | 01:22 PM
BlackGMC's Avatar
Resident Retard
Are you on the factory fuel pump? I would look there next after regapling the plugs like mentioned above
Old Jun 18, 2016 | 05:15 PM
josegbnl01's Avatar
Yeah still has factory fuel system, hopefully its just the plugs
josegbnl01's Avatar
No exhaust leaks bro everything is good
