need cam help
Old Aug 15, 2009 | 10:12 PM
sonoma43's Avatar
TVS for great reliability and power!
FLT Trans FTW
Old Aug 16, 2009 | 07:52 AM
ohioborn80's Avatar
10 Second Club
ya i am looking to a built tranny. also with teh tvs kit it comes with bigger injecters but looking around for fuel rails. think nee dto go bigger then what comes with it. and working on the fuel pump as well. i got 4 months to get every thing ordered and waiting at the house.
Old Aug 16, 2009 | 08:03 AM
ohioborn80's Avatar
10 Second Club
Originally Posted by schino
id definately look into trans' if i were you. 8-10lbs and i dont think it will last long. while your in doin the 3.73's an upgraded locker would be a good idea. 12's on the g80 may be scary
where a good place to look for upgarded lockers.
Old Aug 16, 2009 | 09:32 AM
SuperchargedSS's Avatar
whats your HP goals? I don't think you are going to need new fuel rails with the TVS, or larger injectors. But then again, I'm no expert here.
Old Aug 16, 2009 | 03:48 PM
ohioborn80's Avatar
10 Second Club
hp not sure liek said right now my over all goal is about a 12.5-12.8 1/4. from what i seen and what not im least going to have to make soem where around 380-420rwhp with teh perfect set up every where esle to reach that. that gears, tranny, and least drag radials. i also just ordered a set of caltracks too.
Old Aug 16, 2009 | 03:56 PM
scooter k's Avatar
Check with Joe at LEFTCOAST32 for all of your supercharger needs. Get the TVS and run the 8 rib pulley setup. Leading Edge Performance Blower Cam. Joe will set up with everything you need at a good price. He is also very knowledgable and nows what works what doesn't.
Old Aug 16, 2009 | 03:58 PM
Mangled03gmc's Avatar
Baltimore Whore
Depending on what stall you went with a procharger would work well also.. The tvs is a nice setup, but I don't think that procharger gets enough credit... I do not have any complaints on mine(since I fixed my belt slip), it flat out hauls ***... Def check into a built trans. The stock fuel rails will be more then enough... The gt series cam's are proven to work great with FI setups.. Caltracs are not going to help you out much on the street, but do to a point... Check on ebay for rons machining service, he has the best deals on lockers, posi units..
Old Aug 17, 2009 | 07:34 AM
ohioborn80's Avatar
10 Second Club
hey thank for teh help and where to look. i will do some more research and looking before ordering anything else. I am hoping the caltracs help at the strip and what little they will in the street. Again thanks all for help. next step is getting home and all put to gether.
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
