My "Turbo for Mileage" Project
Old Feb 22, 2011 | 06:54 PM
  #21
brent1976's Avatar
11 Second Club
Where at in Ohio?
Running at 8.6 psi, my milage stayed about the same on the highway, but in town it took a good hit, but I think my 80e+3000 stall is the problem there.
Good luck, it will be cool to see the results, because every once in a while a newb says their turbo will raise their milage, but they are putting it on for more performance, and not running 3 psi, and trying for milage.
Old Feb 22, 2011 | 08:53 PM
  #22
LSRacing's Avatar
Im in Canton Ohio. How about you?
Old Feb 24, 2011 | 05:23 PM
  #23
brent1976's Avatar
11 Second Club
Zanesville, it's probably 2 hours from you.
Old Feb 24, 2011 | 10:27 PM
  #24
Coban's Avatar
Originally Posted by LSRacing
I don't think a lot of people understand how much the turbo should help the truck stay in AFM mode. I'm excited to see how it works with AFM. I already have tuned AFM mode to acheive max fuel mileage FYI.
The mentality of most of the guys on here is, "Oh gosh! stupid AFM! How do I turn it off!??"
It kills me.
I too tuned my AFM to stay on a lot longer than normal. I can go up hills and over-passes with it still on now. I think the 6.2 with AFM could do even better. OR the route you are taking and adding a little extra air in those 4 cylinders. I think it'll really kick *** when the engine loads up a little and it can stay in 4 cylinder.
However, if I remember correctly, one of the enable/disable parameters is manifold vacuum. You might have to do something clever there....
Old Feb 24, 2011 | 11:03 PM
  #25
TURBO8's Avatar
I think its all in the tune and setup. I got way better mileage with the the turbo in my truck. I ran SD tune as well. I dont know about 50% but, I think you ca do much better than stock. I am also doing this as well on my wife's Avalanche. Sts kit is siting in the garage. 62mm turbo, 81 ar, 5psi max, no intercooler, I will be useing a blow off valve thow.I'm saveing money for the tune. Rick at synergy charges something like $600 for a dyno tune now, for FI. That hurts! but he is a great tuner.
Old Feb 25, 2011 | 03:26 AM
  #26
Sinr98's Avatar
Where is the AWD dyno located? I live in Bellevue, just south of Sandusky (Cedar Point). I havnen't found a AWD dyno anywhere in Ohio other than Colombus that will fit my truck. Also how much do they charge for a dyno tune? And do they use EFI Live?
Old Feb 25, 2011 | 07:24 AM
  #27
LSRacing's Avatar
The dyno is located 5 min from the Akron/Canton airport. They do use EFILive to tune. A dyno tune is around $500. I'm hoping for a 20% increase to be honest. We will see.
Old Feb 25, 2011 | 07:28 AM
  #28
LSRacing's Avatar
Here is the number for the owner paThe dyno.
3302085444.
In case you wanted to contact them.
Old Feb 25, 2011 | 07:30 AM
  #29
guero68's Avatar
turbo for milage..sounds like a ford EcoBoost too me...TURBOS are for ***** to the wall tire smoking HP making fun
Old Feb 25, 2011 | 12:07 PM
  #30
TURBO8's Avatar
That too!
