My cam?
I have seen all the threads about the G2-3 and the G2-7 or even the LS6 cam being great for our trucks with magnachargers. I have asked many people in town and over the phone what they thought and they think my cam will be fine. Just want to see what input you guys had. It is a Comp SI Torque Cam, http://www.speedinc.com/cart.cfm?act...em=SI%2DTorque
Thanks for the input
Ryan
Ryan
http://www.speedinc.com/catagory.cfm...in%20/%20Heads
See if that works
It will work, that low of a LSA is not what I would say is favorable but it will work by all means. Actually other then the LSA being low its a good blower cam. Typically you want a 114lsa or higher.
See if that works
to expand on that a little further, as i understand it,
the lower LSA will make it lope and lope is where both the intake and exhaust valves are open at the same time and therefore when you are adding in boost, while you are forcing the air in from the intake side, its just flowing out the exhaust without making you any power.
John
