my boost guage ?
Old Jan 15, 2008 | 11:20 AM
mike06tork's Avatar
Default my boost guage ?
hey guys do anybody know where to get the hose from my turbo for my boost guage because it dosent has anything to connect it do i need to drill a hole in the turo housing or in the intercooler pipeing or where and if i need to drill a hole where is the best way to connect my boost hose closer to the turbo or closer to the trottle body ?
Old Jan 15, 2008 | 11:37 AM
WJ MARK's Avatar
I would connect to the manifold. You can go to the auto parts store and get a universal vacuum pressure guage kit.
Old Jan 15, 2008 | 11:53 AM
thunder550's Avatar
High on diesel fumes
I'd put it into the manifold too....find a vacuum line from the manifold, like the brake booster or PCV and put a T fitting in there, then hook up your boost gauge to that.
Old Jan 15, 2008 | 03:38 PM
mike06tork's Avatar
yeah but what manifold where at at the compressor housing or what
Old Jan 15, 2008 | 03:54 PM
thunder550's Avatar
The intake manifold. Don't bother with the compressor housing....you'll want a boost/vacuum source for the boost gauge, not just a boost source.
Old Jan 15, 2008 | 08:37 PM
mike06tork's Avatar
hey is it better closer to the trottle body or to the turbo and i just weld a tube so i can conect the boost line to the gauge
Old Jan 15, 2008 | 08:50 PM
thunder550's Avatar
You're talking about the intake piping. I'm talking about the intake manifold. Those are not the same things.
Old Jan 15, 2008 | 09:24 PM
Y2KLimited's Avatar
intake manifold is the black plastic thats spread between teh cylinder heads and behind the throttle body, pretty much the top of the motor.
You want to find a vacuum/boost source there for accurate results. My vehicles are all spliced inline off of the brake booster hose, but I have an aftermarket ribbed splice with lil barbed ends for that
Old Jan 15, 2008 | 09:55 PM
Stoichiometric's Avatar
There are some plastic nipples on the manifold that are not always used from the factory, you can break the cap off and use one of those, or T off of another vac line.
Old Jan 15, 2008 | 10:27 PM
mike06tork's Avatar
ok i know what you are talking the intake right so i just break the cap off of one the plasticnipples and connect the boost gauge from their and it will read my boost once i press the gas because in idle its going to be in vac. right
