MP70 problems
Old Jul 7, 2008 | 10:03 AM
2ktransam's Avatar
Default MP70 problems
Anybody have problems with their Master Power turbos? I installed my t70 and it is leaking oil through both seals even at light throttle. I have a .065 oil restrictor in the feed line and my return pump seems to be working fine. I bought the turbo from member so I don't have a warrenty with it but it is brand new so I shouldn't be having these problems.
Old Jul 7, 2008 | 11:09 AM
kbracing96's Avatar
Even if you manually switch the pump to high, does it leak all the time?
Old Jul 7, 2008 | 11:20 AM
bud8fan's Avatar
wow that sux...no problems here....
Old Jul 7, 2008 | 11:42 AM
2ktransam's Avatar
I have been running the pump on high to see if that would help and it doesn't seem to. I tried driving it to the store yesterday and with light throttle and maybe 3psi my truck started surging from it blowing oil into my maf.
Old Jul 7, 2008 | 08:18 PM
DrTurbo's Avatar
LS1TECH Sponsor
MP units are notorius for leaking oil. The compression piston rings they use are very thin and the tolerances they use are loose compared to other units we build. So they are very sensitive to oil pressure and draining.
Old Jul 7, 2008 | 08:56 PM
2ktransam's Avatar
Any suggestions on a fix?
Old Jul 9, 2008 | 06:27 PM
slowec's Avatar
Bump!!!
This sux for you , sorry to hear this,. I was really thinking about using that turbo as my upgrade. Hope you get it straight.
Old Jul 10, 2008 | 02:14 PM
FormerVendor
I am your contact for Masterpower warranty assistance
252-562-3899
Old Jul 21, 2008 | 10:44 PM
2ktransam's Avatar
I believe my problems are solved. Rob over at Modular Turbo gave me a few ideas and I found the problem. Thanks Rob.
Old Jul 21, 2008 | 10:49 PM
RedHot04's Avatar
252-562-3899
That's what I call stepping up to the plate!
