MP T-70 vs MP T-76
Old Dec 14, 2008 | 08:54 PM
nxpress03's Avatar
So what should you run like 88. I was thinking about running a 72 turbonetics on a 6.0.
Old Dec 14, 2008 | 08:55 PM
bud8fan's Avatar
i think you can now get the mpt76 in the p,s and q trim.....
mine runs very well on my cammed 6.0...alot better than my mpt70 on the same motor...
Old Dec 14, 2008 | 09:03 PM
parish8's Avatar
single digit dreamer
there is always some give and take with these things but when comparing the 70 to the 76 you wont see much aditional spool time. just looking at the question of 70 vs 76 on a 6.0 the 76 makes sence.
change the question so you are comparing the mp76 to the pt88 and then there are a lot of things to consider. sure the pt88 will make a ton more power but it will also be considerably more laggy. for a street truck the pt88 might be a bit much and loose some of the fun factor. just looking at the compresor maps the pt88 is a great match for a 6.0 but in real life it takes some of the fun out of driving it.
Old Dec 14, 2008 | 09:13 PM
Derek @ EDO's Avatar
FormerVendor
Really need to look at the map.
Most people assume PSI equals HP but like Jim stated above.. If your out of the efficiency range you might not pick up anything.
Different turbo manufactures use different wheels, covers etc. some are far more efficient than others.
My 83mm outflows some 88mm units on the market.
I would run the new TC78 on a 6.0 for a good street setup.
Old Dec 14, 2008 | 09:19 PM
parish8's Avatar
maps are pretty hard to find for some turbos.
Old Dec 16, 2008 | 10:18 PM
2ktransam's Avatar
I have heard that the STS kit lets you get away with a little smaller turbo for some reason. Is there any truth that? My truck runs really well with the mp70 but I am debating on switching to the mp76 in the spring. Is it worth it?
Old Dec 17, 2008 | 05:35 AM
silver-mod-o's Avatar
Hunt&Fisherator
I think the reason they "say" you can run a little smaller turbo is to make up for the lag associated with the extra piping IMO..... I'd match the compressor as usual, but maybe run a smaller exhaust housing to compensate.
Old Dec 17, 2008 | 09:39 AM
2ktransam's Avatar
I thought it was BS. I turned my boost controller up all the way a couple of weeks ago and the mp70 would only build 13psi with the 6.0L and Z06 cam. I assume the turbo is completely done so I may have to go up to the mp76 soon.
Old Dec 17, 2008 | 09:58 AM
Hunt&Fisherator
Yeah, I'd definitely to a 76 with that many cubes... I would go so far as to say my 70 will only make it to 15psi or so on a 5.7
Old Dec 17, 2008 | 09:59 AM
sureshot's Avatar
Once I get my cammed LQ4 in, I was thinking of going turbo with the mp76. I was thinking of running 10#'s of boost, should I be thinking of running a little more boost, say 12#'s?
