Mounted new Vent Can for Turbo setup...
Old Aug 11, 2007 | 08:54 PM
  #21
Bill Reid's Avatar
Keep us posted bro... all we can do is learn from each other...
Bill
Old Aug 12, 2007 | 02:31 PM
  #22
Slowhawk's Avatar
LS1Tech Sponsor
Lol,I was about to say the vacuum is screwed now until I read the last post.I have customers do this all the time,when they come back and say my tuning is screwed I pull off all the breathers they added and say it's fixed now
For turbo cars I just run a big breather like that with 1 line from each valve cover going into it. If you don't like the fumes and want some vacuum under boost we use a catch can/seperator(big) and run a line to the turbo inlet piping.This will pull a vacuum under boost and help seal the rings.(If you run a filter which creates a slight restriction)
Old Aug 12, 2007 | 03:13 PM
  #23
Bill Reid's Avatar
Ya, I'm gonna add another breather port to the driver side valve cover... now that PCV is removed. I'll tie both valve covers into the breather can. After driving around yesterday and this morning I am not getting any crank case smell after lift so the breather can placement on the frame seems to be working out good. Have you tried an exhaust pipe venturi for crank case evacuation?
Thanks,
Bill
Old Aug 12, 2007 | 06:47 PM
  #24
Slowhawk's Avatar
LS1Tech Sponsor
Thanks,
Bill
I've tried probly everything out there and prefer the catch can with line running to the intake of the turbo the best. Of course most of our Turbo cars are tuned SD with no MAF.
Old Aug 12, 2007 | 08:09 PM
  #25
Wilde Racing's Avatar
How do I change this text
That is a clean set-up. thanks for posting......
Old Aug 13, 2007 | 07:35 AM
  #26
TG02Z71's Avatar
With the line running into the turbo inlet do you get any oil into the intake?
I know most oil is getting taken out through the catch can you spoke of but just wondering if any does end up in your intake.
Thanks.
Old Aug 13, 2007 | 08:02 AM
  #27
Slowhawk's Avatar
LS1Tech Sponsor
Thanks.
You will get oil mist in the intake since it is fumes.Mount the catch can low like the one pictured and it should help.
GXPJAY
Feb 13, 2022 08:15 AM
Zizzle
Oct 19, 2017 08:44 PM
silver-mod-o
18
Aug 25, 2015 08:18 AM
Jake99
Aug 8, 2015 07:56 AM
