missfire #6 Wot only
Old Nov 23, 2013 | 12:07 PM
blownescalade62's Avatar
Default missfire #6 Wot only
Changed from stock delco plugs to NGK TR6 plugs. I now have a missfire on cylinder #6 only on WOT runs. It's very cold here but don't think that should affect things? And it's only on the one plug? Any ideas possible bad plug maybe?
Old Nov 23, 2013 | 01:57 PM
idahoblkss's Avatar
how much boost? what did you gap the plug to ?
Old Nov 23, 2013 | 02:54 PM
9 PSI sometimes 10 PSI stock gap just put them in as is. Its only the one I get the error
Old Nov 23, 2013 | 05:06 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Recheck that plug & wire. Very easy to accidentally crack a plug. Or overlook a plug wire with a weak clip(or even missing clip).
Old Nov 23, 2013 | 05:44 PM
I actually did pull the clip off that wire. put it back on thought it was the wire. So I installed the factory wire in it's place but still got same result.
Old Nov 23, 2013 | 07:09 PM
idahoblkss's Avatar
i would check the gap on that plug. also would maybe try and switch coils with another one and see if it still does it.
Old Nov 23, 2013 | 07:21 PM
Just don't understand why it only does it under WOT? Going to pull plug tomorrow and put in factory Delco plug and see what happens.
Old Nov 24, 2013 | 05:38 PM
Well swapped in stock plug and still have miss under WOT. Now thinking it may be the coil? Wouldn't I get a miss even when not under WOT if it was a bad coil?
Old Dec 8, 2013 | 10:33 PM
Turned out to be a bad intermittent plug wire. Fixed was driving me nuts
Old Dec 8, 2013 | 11:06 PM
Glad you got it figured out!
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Tydriver
45
Oct 23, 2015 09:19 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Brandonlflr12
14
Sep 16, 2015 12:44 AM
