"Misfire with Magnacharger"
hello every one,new to the site....well i just bought a used xl denali,dirt cheap.new car to me...came with check engine light on,code po303.swaped coil,connector and spark plug to cyl 1,still had missfire on cyl 3.sorry should of said it came with magna charger,i know jack about these chargers,anyways,i now the charger comes with injectors....are these injectors known to go bad often???is ther a way for me to test them??
thanx for the help.
thanx for the help.
13 Second Truck Club
thanx for the help.
thanx for the help.
________
Paxil settlements
also check the wiring to the injector, make sure the plug is making good contact, make sure the pink wire has 12v key-on power (the ground is what alternates for the signal) at that point switch that injector from #3 to #5 for instance and seperate it from the previous ignition stuff going to 1, might help you pinpoint easier.
You might be able to get a single injector......but if one's acting up, I'd personally just grab a set......they're all the same age/milage etc. if thats the case I wouldn't want to run the risk personally.
im in torrance caifornia,well after checking injector function,and ,swaping to cyl 5,still had missfire......went back to basics...cyl leakdown test and found rings on cyl 3 took a dump....not good.compression at about 110 compared to all others cyl at 180.according to last owner engine has about 30k,when i removed valve cover all valve train items looked very clean and fairly new....thinking of pulling engine and slaping new rings in it...suggestions????
I suggest you have a professional take a look at your truck. There is a shop located in the San Fernando Valley that we trust will ALL of our So Cal installs and trouble shooting. JPA 818-994-4410, ask for Jeff.
