this might be the quickest stock ls longblock!
single digit dreamer
that car has been a blast. insanely reliable. in the year we have been beating on it we have changed the oil twice, plugs twice, cleaned the fuel filter a few times and put 4 sets of tires on it
. the only problem we had was the tranny messed up on us once. had to do a quick rebuild right before drag week.
we were looking at the logs today. on the last run we turned the boost up but it didn't go up on the launch like it should have. i think we have the 2step set too low for the boost to go any higher. we left at 10.5psi and ran at 14psi on that run. with a 2 step adjustment we should be able to leave at 14psi. if it gets traction i think it could be a bit quicker
if we were really serious we could drop something like 200lbs off the car.
. the only problem we had was the tranny messed up on us once. had to do a quick rebuild right before drag week.we were looking at the logs today. on the last run we turned the boost up but it didn't go up on the launch like it should have. i think we have the 2step set too low for the boost to go any higher. we left at 10.5psi and ran at 14psi on that run. with a 2 step adjustment we should be able to leave at 14psi. if it gets traction i think it could be a bit quicker
9 Second Truck Club
Have you tried more timing, or are you just keeping it safe?
This is from his first post.
