Methanol w/Radix?
Old Nov 29, 2005 | 06:42 AM
JimS's Avatar
Default Methanol w/Radix?
I'm planning to install Meth injection on my 5.3 w/Radix.... if:
If it is safe?
If it is reasonably easy to install (read: I'm a novice, but I did do my Radix)
If I can find a good kit and a good seller.
So; what do you friends recommend regarding what to look at and where to look at it?
Thanks much. Jim
Old Nov 29, 2005 | 09:08 AM
thunder550's Avatar
High on diesel fumes
If you can do a Radix you can do a meth kit. I just did an Alkycontrol kit, Julio is awesome to work with and the kit is very well done. The only potential problem I have heard of is that running straight meth will remove the finish on the s/c rotors, but
i have also heard that running a 60% water 40% meth mix works better and will not damage the Radix. Just what I have heard, so take it for what it is.
BTW...nice truck, and cute dog
Old Nov 29, 2005 | 09:16 AM
F8L Z71's Avatar
We are probably going to install my Alkycontrol kit on my Radix setup. We were gpnna see how it does without it but the more I think about it 10.8CR plus 6psi might be a bit much for Cali octane. LOL
Old Nov 29, 2005 | 01:50 PM
Bad_Apple's Avatar
Hey I just installed my AlkyControl Kit on my truck to it is a very nice kit and setup. And I hid everything so all you can see is a braided line going into the intake. They are very nice kits and Julio really knows his stuff. I've been gone out of town and not got a chance to play with the kit yet.
Old Nov 29, 2005 | 03:44 PM
moregrip's Avatar
what a rush!
you'll be ok bro plus you have a smaller bore which helps out as well
Old Nov 29, 2005 | 03:54 PM
O3GMC's Avatar
12 Second Club
I have the Snow Performance kit, it was easy to install and has worked well. I use 50/50 water/meth, because you get the cooling from the water, the fuel from the meth, and at that mixture it is supposed to be non corrosive. I haven't done much tuning with it besides a/f, but hope to gain alot when I add timing.
Here are a few pics:
Old Nov 29, 2005 | 03:55 PM
moregrip's Avatar
what a rush!
How often do you have to fill up a tank of that mixture?
Old Nov 29, 2005 | 04:30 PM
O3GMC's Avatar
12 Second Club
A quarter mile will use about 1/8 tank, but you'd be suprized how quick you can use half a tank on the street, using part to full throttle once in a while. I found meth for $2.75/gal, so about $1.37 when mixed with water. I just keep a 5 gal race fuel container with the meth and put the mix in a smaller gas can or windsheild fluid container. If I did it over, I'd get a larger reservoir with the low-level indicator.
Old Nov 29, 2005 | 10:39 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Just so ya know, Nitrous cools down intake air temps as well...BWAAAAHAAAAA
Old Nov 29, 2005 | 11:28 PM
CHarris's Avatar
