meth tank?
Old Mar 18, 2009 | 08:58 PM
05crew's Avatar
Default meth tank?
who makes a good meth tank. and can i put the tank and pump in a tool box? or just the tank.
Old Mar 18, 2009 | 09:03 PM
charcold-bowtie's Avatar
If you want one for under the hood, Trick performance makes some sweet *** ones in polished Aluminum.
Old Mar 18, 2009 | 09:20 PM
Sleeper04's Avatar
Snow Performance has some that are 1 gallon and you can get low level indicators for.
Old Mar 18, 2009 | 09:22 PM
05crew's Avatar
can i put it in the tool box and the pump under the truck?
Old Mar 18, 2009 | 09:26 PM
Sleeper04's Avatar
don't see why not. How long of a run would it be from the tool box to the nozzle?
Old Mar 18, 2009 | 09:28 PM
05crew's Avatar
maybe 6ft from the pump to the TB. and 3ft from the tank to the pump on the frame rail some were.
Old Mar 18, 2009 | 09:32 PM
Sleeper04's Avatar
I would check with whoever you decide to use if that distance is ok from pump to tb. It should still be ok but I would check just to be sure. Everything else should be fine.
Old Mar 18, 2009 | 09:38 PM
Sleeper04's Avatar
http://www.snowperformance.net/product.php?pk=35
Here is the one I was talking about.
Old Mar 18, 2009 | 09:44 PM
05crew's Avatar
thanks for the help..
Old Mar 18, 2009 | 09:46 PM
silver-mod-o's Avatar
Hunt&Fisherator
id personally keep it under the hood somewhere... less demand on your pump, and it would probably last a little longer.
