Meth and Radix pulley question??
guys where are you getting a 12 volt /15 amp power source to hook up the red (hot) wire from the Snow progressive controller? also where are you hooking up the boost line from the same controller?? can anyone tell me where to get a 2.75 pulley for my 112 Radix??? thanks Pat.
I found a switched 12v pin on the drivers side fuse pannel. I pulled a 10ga wire through the firewall from the battery to a relay. I used that pin to pull in the relay that feeds all my under dash power needs. The boost line will need to be T-d in to a boost gauge or pulled through the firewall from the manifold.
