METH question
Old Jun 19, 2014 | 12:54 PM
tim wellington's Avatar
Default METH question
when you add meth i know if makes it richer. but to lean out .what are most you doing taking away fuel or add more timing or both .i
Old Jun 19, 2014 | 01:03 PM
timmay208's Avatar
you take fuel out to get the AFR correct, but most add some timing with meth to get extra power
Old Jun 19, 2014 | 02:50 PM
thunder550's Avatar
High on diesel fumes
Yep. Methanol gives you a higher effective octane rating so you can run more timing. That's mostly a separate issue from the fueling...so basically you'd pull fuel and add timing both.
Old Jun 19, 2014 | 03:01 PM
slowec's Avatar
Summer Iat's drop 50 degrees! woohooo . yay METH
Old Jun 20, 2014 | 06:53 PM
FrostKing's Avatar
With water / meth injection the more water content the leaner your wideband will read. It seems to be around 50/50 that they balance each other out and the wideband won't be affected much.
Old Jun 20, 2014 | 07:40 PM
timmay208's Avatar
well you would need to keep the same % that you tune with. Im going to be running either 100% meth or maybe 80/20. Its much easier to run 100% IMO but can get spendy depending how much your spraying
you dont want to tune the truck for 100% meth then run 50/50 as it would throw it off
Old Jun 22, 2014 | 07:37 AM
TIM Z's Avatar
11 sec. Truck Mod
What meth kit do you guys have ?
Don't try running straight meth thru kits that aren't designed for it .
You'll have leaks eventulaly .
Old Jun 23, 2014 | 02:13 PM
Default timing
does it matter which one first . being a nos tuner i know 1deg or 2deg with lean out nitrous a whole lot . i was just wondering example a/f ratio 11.0 add meth then goes fat 10.0 to add timing first before taking out fuel.
Old Jun 23, 2014 | 02:29 PM
timmay208's Avatar
all depends on how much you spray. under 10gph will genearlly make it go 1 point rich but that also depends on what % you are spraying to
Im running snow stage 3 kit
Old Jun 23, 2014 | 08:17 PM
MechE's Avatar
i run 17gph, 14 psi, 16 degrees timing. i just want it daily driver safe. just decrease fuel relative to how much you're spraying, and increase timing
