meth & brake stall boost
Old Jul 8, 2008 | 11:00 PM
  #21
ducky's Avatar
Originally Posted by 4.8T
little over 8 i push through my hydroboost. i'm sure with better pads and rotors it would hold more.
what are you running now with the hydroboost?
Old Jul 9, 2008 | 09:07 AM
  #22
TURBHOE's Avatar
sorry, i don't understand the question. if your talking pad and rotors. they are stock replacements from the zone. and ceramic autozone pads.
Old Jul 9, 2008 | 09:26 AM
  #23
FrostKing's Avatar
Spraying a lot of meth will help build more boost than without. It increases the exhaust volume dramatically.
Old Jul 9, 2008 | 09:33 AM
  #24
TURBHOE's Avatar
well i have a m15 nozzle. is that "alot"
Old Jul 9, 2008 | 09:40 AM
  #25
ducky's Avatar
lol sorry about that. Yeah I was asking about pads and rotors. Thats good to hear your running mostly stock stuff with just the hydroboost and are able to hold 8lbs. I'm looking into a hydroboost setup as well.
Old Jul 9, 2008 | 11:47 AM
  #26
TURBHOE's Avatar
the braking power is there for sure. i've had to hit it hard a few times. when i first got the turbo i didn't relize how fast i was accelerating. i learn that one fast. where i use to go wot to pass cars i now do 40%. i am thining of doing some braided lines. that with some good rotors and pads it would be crazy. that is if i had sticky tires of course.
Old Jul 17, 2008 | 10:18 PM
  #27
gizzmotk's Avatar
I don't think they sponser but coolingmist.com offers a "smart controler" thought about it. run it if i lean out via Wb02, over boost, whatever. but i wanted somethig simple to set up and a little cheaper, so i went with snow insted
Old Jul 21, 2008 | 08:04 PM
  #28
1BadAction's Avatar
Registered abuser
4.8, does your hydroboost pulse or anything when you hit the pedal? or does it feel exactly the same as the vac booster?
I have a 3/4ton HYB system for my 93 with stainless lines all around. just kind of curious how its going to act.
Old Jul 21, 2008 | 08:09 PM
  #29
2004SSS's Avatar
wow you dont have much timing in there.
Old Jul 21, 2008 | 09:09 PM
  #30
TURBHOE's Avatar
mine acts like normal but when i'm boost stalling it kinda vibrates.
