meth
Old Sep 30, 2013 | 01:45 PM
  #21
LS1TRUCKGUY's Avatar
Who is this Julio you speak of and where can I find one of his meth kits??
Old Sep 30, 2013 | 01:52 PM
  #22
Edit: never mind. I found the alky control site
Old Sep 30, 2013 | 05:13 PM
  #23
Random User's Avatar
Originally Posted by Ferocity02
Thanks to California, you can't buy washer fluid in anything lower than +32F
Thankfully you can buy straight meth and roll your own out here.
Old Sep 30, 2013 | 07:15 PM
  #24
dbizzle's Avatar
Originally Posted by slowec
Meth is great! Apparently E85 is more better.
I used meth injection on the inline 5, I couldn't run as much timing as the other guys on e85, so I would say this is true
Old Sep 30, 2013 | 09:04 PM
  #25
smokeshow's Avatar
Mod with training wheels
Again, dependent on how much meth you run... For example a little 5gph nozzle on a 408 at 20psi is going to be like running E10 for fuel. Its not apples to apples.
Old Oct 1, 2013 | 12:19 AM
  #26
dbizzle's Avatar
I have the AEM meth kit, using the largest nozzle which is 550 cc/min (not sure what that converts to for gph) but I could only run 13* of timing safely, I screwed up the piston rings on 15*, while the others can run 19*+ on e85 with no problems
Not saying its the same, just seems like at least on the Inline 5 motor, e85 is the way to go. Other motors may like meth more, I'm not going to claim to know all that or even that my opinion is right
Old Oct 1, 2013 | 12:39 AM
  #27
smokeshow's Avatar
You need to run multiple nozzles to really start getting an octane benefit. For your purposes, e85 is a more user friendly way to go...
Old Oct 1, 2013 | 01:02 AM
  #28
dbizzle's Avatar
Turbo Inline 5 wasn't making enough power for multiple nozzles, which is why I'm swapping to a 4.8 with turbo now and will be running e85 and then just using the meth to cool the intake temps
Old Oct 2, 2013 | 08:08 AM
  #29
9 Second Club
If E85 is readily available, and you can stand the fuel mileage drop then I'd say it's probably a better fuel. What I like about 93+ meth is my truck runs around like a regular truck would burning gas I can get anywhere, then under heavy load cycles the meth picks up the slack of 93 octane fuel. Most of the time a gallon of meth will last me two or three tanks of fuel. You can't beat that for daily driver use in my opinion, but if max power at all times is the goal then E85 may be the best solution.
Mr. Chainsaw
Oct 18, 2015 08:00 PM
turbo6c3
Oct 5, 2015 06:11 PM
JordanH
Oct 3, 2015 03:59 PM
old motorhead
Sep 29, 2015 08:22 PM
gavin2005
Sep 13, 2015 09:04 PM
