Maximum Size Intercooler
Originally Posted by vanillagorilla
What kind of FI setup are you running?
What are your hp/tq goals? How much boost are you running with what size engine? We need more info.
I have the 5.3 with a powerdyne blower and fixing to be running 12lbs of boost. I have long tubes, Z06 heads, cam and intake, 90mm Nick Williams Throttle Body,(all of this I am fixing to install) 42lbs injectors, 255LPH fuel pump, corvette servo and shift kit. I am wanting to get numbers over 500 HP at the rear wheels, do you think I will with this setup? What kind of numbers do you think I will get. I wanting to intercool my blower so it will run that much better.
