Max psi on 6.2L? wit hstock fuel system
Old May 7, 2013 | 01:09 PM
TX Tahoe Z71's Avatar
Originally Posted by thewrx
BAP's are a bandaid, and personally I would not risk my motor with one of those.
Not to be rude, but is this statement based on any evidence or personal experience? Lingenfelter uses these frequently on their high dollar turbo corvette builds and they aren't in the business of cutting corners.
Old May 7, 2013 | 01:23 PM
Atomic's Avatar
I have a gauge for that
Its a fact increasing voltage to a pump will shorten its life. Increasing voltage makes the pump spin faster, which wears the pump faster. How much is uncertain. Could only be 1% difference or could be 50% in terms of lifespan.
Old May 7, 2013 | 01:25 PM
smokeshow's Avatar
Mod with training wheels
Boost a pumps actually make fuel pumps flow less. Injectors might move marginally more, but overall it sort of cripples the fuel system. It really is a bandaid... Read Richard's thread for the proof.
Old May 7, 2013 | 01:36 PM
I agree with that. However, when wired with the Hobbs switch triggered at 4psi, it doesn't see the voltage boost but for a few seconds at a time, so heat buildup and wear should be only marginally more than in the stock application (at least that's how I rationalize it to myself so I don't have to swap to a higher flowing pump).
Old May 7, 2013 | 01:49 PM
smokeshow's Avatar
Your hobbs switch is triggering another pump entirely, no..?
Old May 7, 2013 | 02:42 PM
No, the Hobbs switch triggers the boost a pump to up the voltage (to 17.5V) to the stock pump. Below 4psi, the pump sees 12V.
Old May 7, 2013 | 02:44 PM
smokeshow's Avatar
Thats weird. Is the primary circuit isolated?
Old May 7, 2013 | 03:24 PM
You're over my head
I do know it's wired in line with the gray power wire going to the fuel pump from the fuse box, if that helps.
Old May 7, 2013 | 03:40 PM
ak2007r6's Avatar
Pumps flow more at lower PSI (to a degree).. it sounds backwards and hard to wrap your head around but Richards thread explains it pretty well
Old May 7, 2013 | 03:51 PM
smokeshow's Avatar
Originally Posted by TX Tahoe Z71
You're over my head
The way it sounds like you've got it hooked up now, current flows backwards through the main fuel pump circuit when the Hobbs switch comes on.
