max boost for pump gas in hot weather
Old Aug 25, 2011 | 05:55 PM
Daryn's Avatar
Formerly darynC-10/23/10
Default max boost for pump gas in hot weather
im running 10 right now, but i kinda want to up it a little bit more... maybe 14 or so.. what would be a safe number to turn it up to before it starts giving me problems on pump gas?? .. i have a forged bottom end also
Old Aug 25, 2011 | 06:38 PM
TURBHOE's Avatar
water/meth or no?
Old Aug 25, 2011 | 06:40 PM
charcold-bowtie's Avatar
ya thats the better question^ along with IAT control and how aggressive your IAT timing table is.
Old Aug 25, 2011 | 07:00 PM
1989k1500's Avatar
Im sure it gets hotter where you are but SilveradoL33 ran his L33 with 13lbs on pump gas with no meth and it was fine.
I dunno what your compression is and the like but Im sure with a good tune you could run up around 14lbs. Especially if you run meth.
Old Aug 25, 2011 | 07:28 PM
TURBHOE's Avatar
yeah we need to know compression. pump gas but what octane in your area.
Old Aug 25, 2011 | 07:46 PM
TIM Z's Avatar
11 sec. Truck Mod
Its all in the tuning.
Old Aug 25, 2011 | 09:17 PM
JankesGTO's Avatar
Old Aug 25, 2011 | 10:03 PM
53RUSSELL's Avatar
All in your tunning and what your timing table set at.
Old Aug 26, 2011 | 12:21 AM
grey matter 04's Avatar
13 Second Truck Club
as much stuff as you have broke and burnt u still havent learned!
With the heat we been having 97-103 degrees you better leave it alone.
High IAT with an agressive timing table will definately nip another piston unless u add meth to drop IAT temps.
Your tuner has been known to tune them HOT and aggressive
Old Aug 26, 2011 | 04:40 AM
TIM Z's Avatar
11 sec. Truck Mod
One more thing, after talking with another knowlegable LS person ,
We discussed, why do people put all this time time and money and hard work into a setup and them cheap out on fuel?????
If your worried put some 100 + octane in that thing in case of detonation.
