max boost for pump gas in hot weather
Formerly darynC-10/23/10
im running 10 right now, but i kinda want to up it a little bit more... maybe 14 or so.. what would be a safe number to turn it up to before it starts giving me problems on pump gas?? .. i have a forged bottom end also
Im sure it gets hotter where you are but SilveradoL33 ran his L33 with 13lbs on pump gas with no meth and it was fine.
I dunno what your compression is and the like but Im sure with a good tune you could run up around 14lbs. Especially if you run meth.
as much stuff as you have broke and burnt u still havent learned!
With the heat we been having 97-103 degrees you better leave it alone.
High IAT with an agressive timing table will definately nip another piston unless u add meth to drop IAT temps.
Your tuner has been known to tune them HOT and aggressive
One more thing, after talking with another knowlegable LS person ,
We discussed, why do people put all this time time and money and hard work into a setup and them cheap out on fuel?????
If your worried put some 100 + octane in that thing in case of detonation.
