max boost on factory PCM
Old Dec 9, 2025 | 10:20 AM
Stokes1114's Avatar
5 Year Member
Ok Bud
https://pcmhacking.net/forums/viewtopic.php?t=7195
Plz note this is the development thread. The current version of this OS is v5. You'll have to learn about tuner pro, xdf's, and bin files. If you have the time to read and learn it's well worth it for p01 and p59 PCMs.
Here's v2 with a link to v3. V4 and v5 are on Brandens patron link in the threads. V3 and up are only for p59 PCMs.
https://pcmhacking.net/forums/viewtopic.php?t=7482
Old Dec 9, 2025 | 10:35 AM
Stokes1114's Avatar
5 Year Member
Originally Posted by Stokes1114
You guys need to look into the open source type of tuning and OS. Anything is possible. Boost control, nitrous control and 4 bar map as we speak.
WBO2 closed loop dual bank, etc
Edit.... Launch control as well as boost timing up to 4 bar. The cyl air is nothing that matters with this. Read up with the links provided later in the thread and if there's questions I'll do my best to help.
https://www.patreon.com/turbo_v6?utm...eatorshare_fan
V5 Full Feature List:Engine Speed Limiter Soft & Hard Limit Launch Control Soft & Hard Limit Flat Foot Shift (Manual Only) Larger VE Tables 2 & 4 Bar Tables Boost Control (Open Loop) Base Duty Cycle Table TPS Multiplier Table Flex Fuel Multiplier (Flex Fuel Required) Over-boost Duty Cycle Cut Lean Boost Cut (Wideband Control Required) Over-boost Spark Cut Wideband Input Closed Loop Fuel Control Custom Input Scaling Ready Test & Fault Checking Desired Air/Fuel (Replaces Power Enrichment) 2 & 4 Bar Tables E0 & E80 Tables (E80 for Flex Enabled) Gen 4 MAF Calibration Table Toggle MAF Fueling (Speed Density) Toggle Closed Loop Fueling
Old Dec 9, 2025 | 11:59 AM
RDF1's Avatar
DuNnO
5 Year Member
Id rather just install a Holley ECU....
Old Dec 9, 2025 | 12:02 PM
Stokes1114's Avatar
5 Year Member
That's a good choice if you can.
Just thought I'd supply the info
Old Dec 9, 2025 | 12:15 PM
RDF1's Avatar
DuNnO
5 Year Member
Once you try and get that fancy with a stock PCM its almost a no brainer to go with a aftermarket ecu thats designed to do all that.
I install Dominator ECU's in 75% of the builds these days to make it very simple and have it programmed with all the safeties needed.
Old Dec 9, 2025 | 01:59 PM
Stokes1114's Avatar
5 Year Member
Ya I can see that. The thing is this costs nothing. It's something that you have to want to do though. I've been hacking PCMs for years so it's part of the hobby for me. If you have the money and no desire to look into it then that's perfectly fine.
Go5.3tt06
May 13, 2016 11:49 AM
Truckeez
Feb 11, 2016 11:15 AM
5.3 GMC
Feb 2, 2011 05:13 PM
James B.
Dec 20, 2006 12:59 AM
03red5.3
Jun 16, 2004 09:16 PM
