MAP sensor for 18 psi
Like the title says, what MAP sensor should I use if I'll be running up to 18 psi on a turbo build? The duramax MAP looks good, (part # 12623671) but I don't know if that's the best option.
A 2 bar sensor is good for about 15 PSI. A 2.5 bar sensor is good for about 22 PSI. I make the 2.5 bar sensor as GM does not make them. I just finished 2 of them about an hour ago. If you are interested, I sell them for $70 shipped to the lower 48.
Just to inform people of the problems with diesel MAP sensors. A diesel engine does not create engine vacuum like a gas engine. When you let off the gas on decel, the kPa drops down. The sensor above (12623671) only goes down to 36 kPa, so anything below that is not recognized and will cause a rich condition. You more than likely will not be happy with a sensor designed for a diesel engine. I honestly don't care if someone purchases from me, but just be aware if you want a Duramax sensor.
Cobalt ss TMAP sensor number 90423637 (2.5 BAR)
Pigtail for TMAP sensor number 88988320
there are two different map sensors that came in the cobalt tc. one was a 2 bar direct plug in for the ls engine and the 2.5 bar is a 4 wire plug which has the ait sensor in it.
not sure if this is correct, but maybe worth looking into?
